03-14-2022, 07:27 PM | #1 |
Rep 18
N55 Misfire Fun
Team,
I'm having an issue with a persistent and very intense misfire. Story time...
These faults and my findings are slowly leading me to diagnose a faulty DME (possibly shorted or damaged somehow by the O2 sensor wiring fault?), as it's complaining about x2 faulty elements (O2 sensor and valvetronic) that don't appear to be faulty and neither do their wiring back to the pins on the DME itself - not to mention the oddly high fuel trims. Any help or advice appreciated. Thanks, Lox |
03-14-2022, 07:56 PM | #2 |
Rep 196
Finally a case that isn't just another random asking why their newly stage 2 car has terrible timing on the original plugs.
Oil cap vaccum is normal. Mine sucks it back out of my hand with confirmed PCV function and spotless smoke and boost tests. The car is literally telling you it's not getting the proper data from the oxygen sensor/s. Don't look for extraneous issues when you began having issues attributed to that direct issue. The disconnect code and screwed up trims are because of this. Running without proper O2 sensor signals is like trying to drive around a track blind by feeling where the curbs are through your steering wheel. The likelihood of another massive failure happening at the same time is low to none unless it is because you ran into the curb because you were blind. You would likely have other codes if it was an organic DME fault. However the valvetronic code does sound like something - especially since it didn't get fixed with the new motor. But those are different systems. Please post the codes and a log. Including oxygen sensor voltages on the log. Does your exhaust smell like straight gas? From simple to less likely: Did you get the right sensors? Are they installed in the DP in the proper orientation front/back? Are you sure you didn't mix up the blue and black connector and connect them backwards on accident? Sounds like your plugs have had a hard life lately. Maybe they got totally soaked out, could explain the misfires. Put some new ones in and see if that changes everything - swapping them around won't do much when you're having problems across the board. Do you have confirmation that the valvetronic mechanics are actually able to move and are functioning? The car commanding changes but it mechanically not happening could explain somewhat. What are you comparing the pulse width to, in order to get to the conclusion that it's long? The DME is so in tune with those things if that was an issue (and not a symptom of another issue) it would throw a code.
14' Alpine White M235i 6MT, BM3 Stg2+, VRSF DP-CP-FMIC, Dinan Muffler, GFB DV+, 3.5 bar MAP, Dorch Stg1 HPFP, NGK 97506, BM3 Flexfuel Kit, CDV delete, KW V3, EDC delete, Powerflex Camber LCA bushings, VMR 801 18x8.5/9.5 et45, Conti Extremecontact 235/265
Next step: M2 Competition or Manual Supra MKV build Summer 2022 |
03-20-2022, 04:48 PM | #3 | |
Rep 18
Thanks for the reply man, really appreciate the guidance. To respond to a few of your points/questions...
I'm leaning towards either a partially fried DME, or that the valvetronic fault is somehow choking the engine (and this may also be caused by DME issues given every other component in the valvetronic system bar the DME has been ruled out). As ever, any assistance or suggestions are greatly appreciated! Luke |
03-20-2022, 05:56 PM | #4 |
3615
Rep 3,585
Is the replacement pre-cat Lambda sensor an LSU 4.9 or LSU ADV? The ISTA provides output mapping for both, but they have a different relationship between Lambda value and voltage.
If the voltage is measured relative to the sensor output as opposed to ECU interpretation (often the ECU will have it's own 0 to 5V range that is normalised to the Lambda Sensor range), then Lambda 1.00 is 1.5V for the Bosch sensors, whether 4.9 or ADV. If it uses a normalised ECU range for voltage, then 2.5V is usually mapoped to Lambda 1.00. This would indicate you are running lean if it is the sensor output voltage. Here are the Bosch datasheets for each sensor: https://www.bosch-motorsport.com/con...or_LSU_4.9.pdf https://www.bosch-motorsport.com/con..._pre_Turbo.pdf |
03-20-2022, 06:41 PM | #5 | |
Rep 18
Oddly, ISTA reports the air fuel value from the pre-cat as lambda 1.3, which doesn't add up, but anyways. The DME also reports a mixture adaptation value of 1.0 (no adaptation required in either direction) surely meaning it thinks its stoich? But if we are truly lean then shouldn't the adaptation value be 0.something? rtl32 / aerobod - any idea what's going on here fellas? Thanks in advance for your help... |
03-20-2022, 08:11 PM | #6 |
3615
Rep 3,585
Next I would re-check the plugs carefully for any mismatch in colour, then look towards a possible faulty injector, bad plug or faulty coil in any cylinder where the plug doesn’t match the rest, as the Lambda values aren’t necessarily as consistent as expected. I know you have already done some of this, but have you eliminated the ignition by having the misfires stay with a given cylinder after moving the plugs and coils?
From a logging perspective I would see if any individual cylinder values (such as timing) are also different on any one cylinder. It is also worth borrowing or buying a cheap fibre optic camera if you don’t have one, to have a look around inside of the cylinders and look for any signs of pre-ignition on the piston crowns. There are quite a few on Amazon for around £50: https://www.amazon.co.uk/Inspection-...ode=5136303031 Last edited by aerobod; 03-20-2022 at 08:44 PM.. |
03-31-2022, 10:33 AM | #7 |
Rep 18
Thanks for your help guys. Oddly after blow torching and cleaning the plugs, letting the cylinders dry out, and putting everything back it seems to now be on 6 cylinders, although the rough running figures in ISTA do show a bit of unevenness, which I can physically feel too - mainly on cylinder 1 and 4.
The coils on cylinder 1 and 4 are showing a lower amp draw using the amp clamp and oscilloscope (despite resistance of the coil and plug looking good, and ground continuity for the coil and plug via the block also looking good) so I've gone ahead and ordered 6 new plugs and coils. I'll drop an update in when the new plugs and coils are installed and tested. Not sure why the fault was previously not moving cylinders when swapping plugs and coils over, which is normally the go to method for troubleshooting. I've removed injector 4 (possible bad), and injector 3 (seems good) to have them bench tested at a facility to help rule out faulty injector. Valvetronic issue appears to be unrelated, looking back through ISTA history logs it was there before the misfire. Raised a separate thread for that: https://www.2addicts.com/forums/show...2#post28748692 |
