01-17-2022, 02:43 PM | #1 |
Rep 344
Emission light
Emission light came on today. Tuned the car to stage one BM last year. It has charge pipe/catted aftermarket dp/m perf exhaust.
Should I put in the obd stuff and read the code. Should I be worried it's something other than emissions? |
01-17-2022, 02:57 PM | #2 |
Rep 107
Is it a check engine light? If yes, I would plug in the OBD and read the code. Catted downpipe, depending on which one you got, can usually hold off a check engine light for a while but eventually will set it off. Might have to go into BM3 and find a way do disable catalytic monitors. Not sure if that is possible on Stage 1 though.
2016 M235i RWD 6MT, Full E85 Custom Tune via BM3, Stock Turbo, DS2 hpfp, stock lpfp, VRSF bolt ons, CTS Turbo Inlet
01-17-2022, 03:01 PM | #3 | |
Rep 344
01-18-2022, 09:35 AM | #5 |
Rep 196
Tunes are remarkably hard on cats, especially aftermarket cats that are already much less "functional" (in an emissions sense) than stock. Burbles literally coat the element in gas and melt it as the gas lights off..
You have likely degraded your cat to the point where it is less functional than necessary for the vehicle to register it as properly metabolizing the exhaust. This can be because it just wore out because it's a skimpy high flow aftermarket cat, or you could have beat on it with burbles/tune, or anywhere in between. I suggest just turning off the emissions monitors on bootmod3. If I were you I would take the cat off and visually inspect to make sure it isn't clogged- a clogged and disintegrating cat can cause particulate junk to back through the turbo/exhaust valves/cylinders causing a lot of damage. More realistically if i was ACTUALLY you I would just take the thing off and go full catless! Have you noticed any difference in throttle response/driveability lately?
14' Alpine White M235i 6MT, BM3 Stg2+, VRSF DP-CP-FMIC, Dinan Muffler, GFB DV+, 3.5 bar MAP, Dorch Stg1 HPFP, NGK 97506, BM3 Flexfuel Kit, CDV delete, KW V3, EDC delete, Powerflex Camber LCA bushings, VMR 801 18x8.5/9.5 et45, Conti Extremecontact 235/265
Next step: M2 Competition or Manual Supra MKV build Summer 2022 |
01-20-2022, 06:12 AM | #6 | |
Rep 344
01-20-2022, 10:37 AM | #7 |
Rep 196
I mean anything is possible but there is usually at least a 5 degree fluctuation of temp any other day as well so..
03-22-2022, 06:03 AM | #9 |
Rep 344
Yeah so guys an update the light comes on every few days stays on for about two days then goes away on its own and comes back rinse and repeat. What should I do?
03-24-2022, 05:37 AM | #11 |
Rep 344
I'll bring it to the mechanic and have him check it out hoping it's just the sensor. If the cat is let's say blown out… what options do I have? Could I technically have them remove whatever is left of the cat? And essentially just run that pipe as Catless?
03-24-2022, 07:48 AM | #12 |
Rep 198
I dont know of any shop that will do that esp if you live in a state requiring emission controls for inspetion.
