09-25-2021, 01:49 PM | #1 |
Rep 5
How easy is it to work on a B58 ?
Hi. Looking to buy and F22 or F23 with a B58 in it. I have worked on Audis before and am looking for some sense of how difficult it is to do things like: belt change and valve gasket cover changes.
I had some cars where you had to remove the front bumper or drop the engine to do a belt change. I'm hoping that's not the case with an F22/F23 M240XI. Thanks. |
09-26-2021, 09:06 AM | #2 |
Rep 1,264
BMWs, as with all other cars, have become increasingly "diffcult" to work on. By "difficult" I mean that:
- you have to remove more "stuff" to perform the maintenace task - you may need a special tool or tools to perform the task - the access to parts of the engine is restricted So, I find working on a RWD car much easier than a FWD/AWD car as the engine has a fore/aft orientation. |
Cos270608.50 |
09-29-2021, 08:22 PM | #4 | |
Rep 4,906
10-14-2021, 03:19 PM | #6 | |
Rep 1,797
Check what the DIY vids recommend.. but I would probably replace it if you're in there anyways. |
10-15-2021, 09:57 AM | #7 |
Southern Fried
139
Rep 140
I just installed my AA catted downpipe in my driveway. It was a pretty easy job with a floor jack and jack stands. Overall took me about 2 hours and here's what I can tell you from the experience. 1. buy a spare V-band clamp. I had to cut the bolt on mine to get it off. 2. Buy a new gasket! My AA came with a new one, but why risk a leak and having to redo the job? The gasket and V-band are both cheap insurance in my opinion.
10-16-2021, 03:11 PM | #8 |
Rep 166
Drives: '21 EB 240, G87 M2 (preodered)
I've done a full turboback exhaust system as well as a charge pipe and intake, and have found it to be relatively simple to work on. Re: maintenance, the only things I've done so far are swapping brake fluid (and throwing in stainless lines) and one oil change - both were pretty easy. The hardest part on the oil change was getting the oil filter housing cap back on but so far, I'd call it pretty "easy".
Can't speak on belts or valve gaskets though.
2021 EB M240 6MT: TC Kline Camber Plates & Coilovers, Eventuri CAI, AA Catted DP, Remus Non-Res Catback, FTP CP; M Front Lip, Rockers, Mirrors, Spoiler, Interior
02-27-2022, 09:46 PM | #9 | |
SupremacyXI
14
Rep 13
Drives: 2018 BMW 440i, 2021 BMW M3 6MT
2018 Individual Valencia Orange 440i M Performance Edition - MPPSK | 1 of 50
03-01-2022, 05:58 PM | #10 |
Rep 196
B58 fuel pump, turbo, air to water charge cooler, etc are right on top of the engine. Compared to n55 and n54 way, way easier. You could do a full big turbo stock block b58 build in a day on stands with a floor jack. Turbo + pump + intake + downpipe + plugs and you're making big power. That's it.
Valve cover is the same. On top. If you're one to get hung up on plastic clips and stuff then yes it'll take more time an an exposed engine. But thats negligible. Vanos or timing chain work? Pull the engine since it's in the back. That still lives up to the BMW reputation.
14' Alpine White M235i 6MT, BM3 Stg2+, VRSF DP-CP-FMIC, Dinan Muffler, GFB DV+, 3.5 bar MAP, Dorch Stg1 HPFP, NGK 97506, BM3 Flexfuel Kit, CDV delete, KW V3, EDC delete, Powerflex Camber LCA bushings, VMR 801 18x8.5/9.5 et45, Conti Extremecontact 235/265
Next step: M2 Competition or Manual Supra MKV build Summer 2022 Last edited by rtl32; 03-01-2022 at 09:51 PM.. |
03-01-2022, 09:01 PM | #11 |
Rep 4
I'd say its a relative easy engine to work on. I also thought N55 was ok too. Depending on engine bay size might change your experience tho (my B58 is in my M40i, bit larger)
03-09-2022, 09:56 AM | #12 |
Rep 87
I just did the downpipe recently on my F22 b58
Took me about an hour to unbolt everything, take out the sensors Took me another hour to wiggle the downpipe out First time doing a job like that, and it was pretty fun
2015 F30 335XI PS2 FBO SOLD
2017 F22 M240i xDrive |
03-23-2022, 10:24 AM | #13 |
Rep 4
Oil Change DIY
I did an Oil Change with LiquiMoly MolyGen (5W-40) for the summer months.
Took me about 1 hr to do. Fairly simple and there are no catches |
