07-10-2020, 09:37 AM | #1 |
Rep 2
2015 M235i - baseline dyno
Hey all,
Purchased this car in Oct of 2019 with ~15k miles. Recently got bit by the mod bug and wanted to get a good frame of reference as to where I’m starting from before slapping things on. Anywho, wanted to share the results of my stock baseline on a somewhat hot day (102 degrees!) |
07-10-2020, 01:49 PM | #2 |
Driver - Autocross
74
Rep 178
If that number beside wheel hp is actually what you got then your car's severely underperforming. Stock M235is put down 300 to 320 at the wheels.
16 M235xi 8ZF Black on Red FBO: Xhp trans tune -BMS Intake - VRSF Catless DownPipe - VRSF CP - VRSF Muffler delete/resonator - n22 plugs - MHD stage 2+ 95map - Wagner EVO II Preformace IC - Rear seat delete - weight reduction/stripping -FTP 18.5in rims - Hawk HPS front pads - StopTech STR 660 fluid
07-10-2020, 01:53 PM | #3 |
Rep 5,369
The numbers you're quoting are for Dynojets. This is a different dyno this different readings/calculations.
The_otherM235i73.50 |
07-10-2020, 04:10 PM | #4 |
Rep 2
Thats correct, this shop I went to uses a MAHA dyno. With the specified SAE correction it measured 287whp which seems to be inline with other ratings I’ve seen on this forum, albeit slightly lower than a typical dynojet.
07-10-2020, 06:28 PM | #5 | |
Rep 674
Is 305 factory numbers ? Only thing I saw online. Last edited by 4Hockey4; 07-10-2020 at 06:38 PM.. |
07-12-2020, 05:22 PM | #6 |
Rep 4,137
That graph says that the air intake temp was 109F! That’s really hot, and would explain why this car is reading lower. First mods should be an intercooler and Chargepipe.
08-07-2020, 06:45 AM | #7 | |
Rep 226
Yeah mine put down 290 in stock form on a Dynacom |
08-07-2020, 05:03 PM | #8 |
Rep 439
Drives: 2016 M235i Xdrive 8A
Yeah I thought 290ish was the widely accepted figure? Varying slightly based on dyno and that.
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete |
