2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Diverter Valve
      11-25-2019, 03:23 PM   #1
123Britt
Drives: 15 M235i AT
Diverter Valve
Anyone replace their diverter valve as preventative maintenance while the access is available when replacing the Water Pump & Thermostat?
I am just running everything stock - so I thought the $80 dollars to remove and replace the DV located on the turbo would be a good idea once I have the WP removed. Just replacing the Stock DV with similar stock & not the GFB DV+ that tuned motors might benefit from.
      11-25-2019, 08:59 PM   #2
accs
Why not replace with GFB if you're in there...
      11-26-2019, 05:00 PM   #3
123Britt
Drives: 15 M235i AT
Yes - the gfb dv+
Yes - after looking into this further -- I guess this part is superior to the OEM and would perform better even with a stock boost set-up.
Search this Thread:
