2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Show Off your Non-VMR wheels!
      04-24-2017, 12:16 PM   #111
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Originally Posted by csg View Post
PSA to anyone looking to buy the 18" Sportline 8S, the 18x8.5 ET45 will rub on the front strut without spacers. I just found this out the hard way. Also stock tires on these are streeeeetched! Ordered 5mm spacers for the front to try it out, otherwise there will be a brand new set of these for sale soon...
I used a 12mm spacer in that pic FYI. I never tried them without spacers. With OEM tires there will be stretch. Can easily fit a 235 or maybe a 245 if you want. My front setup is still for sale too. Also have 15mm spacers for sale.
      04-26-2017, 01:54 PM   #112
mibikin
Drives: Alpine White M235i xDrive
Originally Posted by BM235iW View Post
My particular setup is:
Apex EC-7 wheels;
Front: 18 x 8.5 +45 w/ 3mm spacers
Rear: 18 x 9.5 +52 w/ 3mm spacers
Nitto NT-05 Tires;
Front: 235 x 40 x 18
Rear: 265 x 35 x 18
Suspension:
Dinan Performance Spring Set w/ Supplemental Ride Quality & Handling Kit
I would like to extend my thanks to first, Crevier BMW for installing the suspension and alignment then second to EAS for the tires, rims and balance. Both very professional and taking pride in their work.
Any issues with rubbing? I'm looking at doing either the ARC-8s or EC-7s in these sizes with 3mm spacers with the same tire sizes but on Michelin tires
      04-26-2017, 06:44 PM   #113
BM235iW
BM235iW's Avatar
Drives: 2015 Black Sapphire M235i
Apex EC-7 wheels;
Nitto NT-05 Tires;
Rear: 265 x 35 x 18
Suspension:
With the 235x40x18 front tires I might have to roll the front fenders because of the inner lip but I think I'll go back down to 225x40x18 tire, should be enough to clear. No issues in the rear, no rubbing wit 3mm spacers installed.
      04-26-2017, 06:55 PM   #114
BM235iW
BM235iW's Avatar
A frontal picture to better show figment. Hope this helps. Michelins will wear longer than the Nitto tires, car uses the rear tires up fast.
      04-26-2017, 09:53 PM   #115
mibikin
Just another question I noticed you say you have a 52 offset in the rear but I'm not seeing that offered only a 58 did you make a mistake or did apex used to make a 18x9.5ET52 in these wheels and no longer does?
      04-26-2017, 09:56 PM   #116
BM235iW
BM235iW's Avatar
Good eyes, my typo, my bad. It is in fact ET58 and thanks for letting me know. I will fix the original post.
Have fun and I'm sure you'll enjoy whatever combinations you pick. Please post pictures.
      04-26-2017, 10:17 PM   #117
mibikin
Alright cool thank you and yes I'll be sure to post them as soon as they're bought and on the car should be about another month or so
      05-24-2017, 07:00 PM   #118
csg
always learning
csg's Avatar
57
Drives: fast, takes chances
Sportline 8S (same as Anthony235)
Front:18x8.5 ET45 with 5mm spacer (required to clear strut body)
Rear: 18.9.5 ET45 (on current set up, protrudes 3-5mm from fender)
Tires are all OEM
Suspension: DINAN springs (with bump stops), stock shocks/struts
Tuna: Now with springs as well as new shoes. by Colby Gregory, on Flickr
-Colby
2020 M2C (his)
2022 Audi A6 Allroad (hers)
1997 Land Rover Defender 300TDi (ours)
      08-07-2017, 11:45 AM   #119
JSCD
Drives: BMW M240i
Originally Posted by jeffery_stearns View Post
Niche Misano M117
Front: 19x8.5 ET 35 235/35/19
Rear: 19x9.5 ET 35 255/35/19
Michelin Pilot Super a Sports
Any rubbing?
      08-11-2017, 01:41 PM   #120
CanadianGatorBacon
CanadianGatorBacon's Avatar
Drives: M235i (holy crap!)
Originally Posted by Panzer1 View Post
Really like your wheels. I've got an M240i xDrive with OEM 7.5 x 18 wheels with 225/40/18 All Season Tires. I understand my tires will fit on an 18 inch wheel. Would these Apex Aero wheels work without any other modifications?
I haven't done any modifications. These wheels fit like this as is.
Gone but not forgotten: 1992 Buick LeSaber Limited | 1999 Acura CL 3.0 | 2003 Volvo S60 2.4T | 2006 BMW x3 3.0i | 2009 Honda Fit Sport
      10-19-2017, 08:35 AM   #121
ttntm
ttntm's Avatar
Austria
Drives: '15 F22 218d
2015 BMW F22  [0.00]
Breyton GTS-R in
18x7.5 ET 45 225/40/18
18x8.5 ET 48 245/35/18
Dunlop Sport Maxx RT 2
2015 Alpine White F22 218d Sport Line | Pictures
      10-23-2017, 04:48 PM   #122
Expert@ApexWheels
Expert@ApexWheels's Avatar
3530
Drives: M3
2015 BMW M235i:
Front: Race Silver EC-7 18x8.5 ET45 with 235/40/18 Nitto NT-05
Rear: Race Silver EC-7 18x9.5 ET58 with 265/35/18 Nitto NT-05
      10-23-2017, 05:24 PM   #123
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
18x9.5 +45 (+25 front with spacer)
255 square RE71
Appreciate 4
WillOs7.00
Taunto281.50
ngl118.00
Rick24913.50
      10-23-2017, 10:21 PM   #124
cxp213
cxp213's Avatar
313
^ Love the spec! Looks like your fenders were rolled. Was it a requirement to run that spec?
I'm trying to figure out if I can run 18x9 +42 all around on 255 RE-71Rs (with spacer in front). Currently lowered on H&R springs.
      10-24-2017, 01:46 AM   #125
mikeyymonster
mikeyymonster's Avatar
Drives: 2021 M2C
SV305S
2021 M2C
2014 M235i
Instagram: @mikeyymonster
Appreciate 10
      10-24-2017, 09:14 AM   #126
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
You will need some way to get more camber up front. H&R springs are pretty low which will make it more difficult also. You should not need to roll any fender. You will probably need a spacer though.
      10-24-2017, 12:18 PM   #127
cxp213
cxp213's Avatar
313
Thanks. I don't mind doing camber plates for more camber. My main concern is just fitting the damn wheels and tires first then I'll worry about specifics to avoid minor clearance issues.
      10-25-2017, 10:54 PM   #128
Dino171
Drives: 15 228
255 square RE71
This looks fantastic!
      11-01-2017, 07:41 PM   #129
wstntime
wstntime's Avatar
Drives: 2015 M235i Performance Edition
2015 M235i Performance Edition BSM - Stance Wheels
Stance Wheels - SF03 Gloss Black - Machine Tint
F: 18x8.5 ET35 (stock mpss 225/40/18)
R: 18x9.5 ET45 (stock mpss 245/35/18)
Current: 2015 M235i Performance Edition, Black Sapphire, 6MT, stock suspension(adaptive), 18's
Past: 428ix AW on black
Taunto281.50
      02-17-2018, 05:25 PM   #130
Nickz95
Nickz95's Avatar
Australia
Originally Posted by Tano22 View Post
Any details on wheel size and tyre size?
I'm looking at getting some BBS ones myself
      02-17-2018, 05:41 PM   #131
mikeyymonster
Drives: 2021 M2C
Here's another of my sv305s
2021 M2C
2014 M235i
Appreciate 4
Taunto281.50
WillOs7.00
Mehim76.50
      02-17-2018, 10:37 PM   #132
KAY-OS
KAY-OS's Avatar
124
Drives: BMW m235i F22
Rays G27 Progressive model
Front: 19x8.5 ET36, tires AD08R 235/35
Rear: 19x9.5 ET45, tires AD08R 255/30
KW V2 coilovers, dinan camber plates.
Appreciate 5
