2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB can't fill fuel tank
      09-09-2015, 05:36 PM   #1
Smallm
Old Member
56
Drives: 2015 M235i, Dinan stage 4
Anyone have trouble filling their fuel tank ? I have to hold the fuel nozzle upside down to get the fuel in the tank, It's the same with recovery or non-recovery type nozzles, My stealership in Sacramento says there's nothing wrong with it .
      09-28-2015, 10:33 PM   #2
JibHonk
Drives: 15 m235i
I leave the car running and that solves the problemsl
      04-24-2016, 02:08 AM   #3
sublimegolf
Drives: 2016 M235i
I thought I was the only one having that problem. I've only had a couple fill ups but haven't been get it work yet. Let me know if figure it out. Anyone else?
      04-24-2016, 09:32 AM   #4
gtmax500
Drives: 2016 MW M235xi
2016 BMW M235xi  [0.00]
I do have trouble filling my tank sometimes, the auto stop function of the nozzle engages instantly some times or before the tank is actually full other times. I have to basically force it in as far as possible and hold it tipped up a little for it to work. I'm used to it now and found the trick but it's still a little annoying.
      04-25-2016, 01:27 PM   #5
robman23
Drives: M235
I have had success with forcing the nozzle pipe down into the car with the handle on the nozzle directed towards the rear of the car.
      04-25-2016, 07:19 PM   #6
xantdieselx
Kingslayer
xantdieselx's Avatar
No_Country
411
Drives: 23' M3 Base
Same issue - well sort of. My car is brand new and first time I filled it up the pump shut off and I thought it was full. Got in, started driving and noticed that the needle was slightly under the F.
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i
Current Cars: 2019' X3, 2021' M3 Comp
      05-01-2016, 10:05 AM   #7
Tpeterson
Tpeterson's Avatar
Drives: 228i MSport/THP/MT/
I haven't had this problem at all. It sure sounds like a venting issue.That would be the evap system which is covered by the emissions warranty. So you have a long time to sort it out. (8-10 years)
      05-07-2016, 06:45 AM   #8
zipphreak
No_Country
454
Drives: m235xi
Don't leave the car running when filling your car.. That's silly and wrong.
Don't fill your tank past when it clicks, if you do you are going to fill the EVAP's Charcoal Canister with fuel, and ruin it. After a while it will no longer do what it was designed to and it is a pricey item to replace.
