2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning M performance exhaust
      08-30-2020, 07:42 PM   #1
Rollo`
Drives: 2018 230i
Is there an M performance exhaust for the 230i? could not find one on getbmwparts.com
      08-30-2020, 09:47 PM   #2
Sisyrx
Budget Enthusiast
Sisyrx's Avatar
243
Drives: 2017 230i M-Sport
2017 BMW 230i  [0.00]
Yes there is but I do not have the model number notated. I *think* it's the same as the 330i.
2017 230i // Estoril Blue II // M-Sport
      09-02-2020, 06:54 PM   #3
Winemaker2
Drives: 2017 230i MSport THP Dinan V2
I have not seen a MPE exhaust for a 230i. 330i, yes. Not sure if it fits but you could inquire. I love my Dinan free flow exhaust and it's a few dollars less expensive.
      09-02-2020, 08:11 PM   #4
Rollo`
Drives: 2018 230i
Where is the best place to get the Dinan exhaust? Don't some folks sell them for less than Dinan themselves do?
      09-06-2020, 11:17 AM   #5
VitaminF22
VitaminF22's Avatar
Drives: BMW 2017 230i
Ive been doing lots of reseach, any muffler section from the 235i-435i models will fit if you have the dual exhaust diffuser conversion!
      09-06-2020, 05:49 PM   #6
aftercorbu
aftercorbu's Avatar
Drives: 20 M2C, 20 S3
And I believe the 328i m performance exhaust will cut right in as well if you don’t want to swap out the rear diffuser. At least that works for the 228i anyway. Haven’t really dug into this in detail though.
Rollo`124.00
      09-06-2020, 08:17 PM   #7
Rollo`
Drives: 2018 230i
I have read that you can replace the 230 with the 240 exhaust but not sure I want to change out the diffuser. I guess I need to do some research on the diffuser replacement.
      09-06-2020, 10:09 PM   #8
Sisyrx
Budget Enthusiast
Sisyrx's Avatar
243
Do it. The aesthetics of the pipes alone are worth the diffuser swap. Did this myself and it really is transformative to the car's rear.
      09-07-2020, 06:49 PM   #9
Winemaker2
Not sure unless they are used. I have purchased both directly from Dinan and from an Indy performance shop I like and the prices were the same.
      09-10-2020, 01:48 AM   #10
mb67
In search of the perfect cup of coffee
mb67's Avatar
Drives: 2015 228i Conv
If your car has the M-Sport package, (which includes the proper bumper) you can upgrade to the M235-M240 M-Performance Exhaust, as long as you get the proper diffuser. There is some question however if it will work on the convertible models, which is the situation that I find myself in presently. But the Coupe will be able to do it.
      09-13-2020, 10:13 AM   #11
VitaminF22
VitaminF22's Avatar
Hey guys, i just received a muffler off the 335i F30 for my 2017 230i and I see that it has a sensor plug-in / valve thats built into the muffler. Will this sensor/valve work with my 230i? On the OEM 230i exhaust it has the same device/plug-in at the same location of the exhaust but I don't have a hand held device like ive seen before to operate the actual valve, but maybe the drive mode i'm in will open and or close the valve?
      09-15-2020, 06:48 AM   #12
Tyresian
Drives: 2018 230xi
Sport Mode / Sport Plus will open that valve.
The connection should be compatible.
