2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Bimmercode, ODBII, and factory/extended warranty
      12-28-2018, 05:47 PM   #1
wichitagreg
Drives: 2016 M235i Cabriolet
Does changing anything with Bimmercode void the warranty?
Such as radio off with ignition, doors lock with engine off.
I just want to personalize a few things, not change any engine codes or "tune".
I have about 11 months of the factory warranty and two more years of Premium after that.
Best not to mess with it?
I've already plugged in the ODBII scanner in a non-registered copy of Bimmer code and looked around. I'm assuming that didn't save anything into ROM ??
Or would the Radio/Nav warranty be voided only if those codes were adjusted?
Car is stock and will remain so. (My goodness, how fast do you really want to go anyway!!)
      12-28-2018, 07:55 PM   #2
Hpirx
Drives: 2022 M240 xDrive, BGM
Mess away!
A little tasteful coding with BimmerCode will not void any warranties, especially if you stay in the
Non-advanced mode. Changes can be reversed relatively easily if the need arises.
The correct answer to your last question
though, in my humble opinion, is;
"As fast as freakin possible!"
Happy Motoring!
Retired: '08 335xi E90. "Long may you run."
Retired: '19 M240xi "You also"
