2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Titan Wheel Thread - 235i Square set up thoughts
      08-30-2020, 11:58 AM   #155
Si-M240i
United Kingdom
137
Drives: M240i LCI
Originally Posted by Devil doc View Post
Originally Posted by 4Hockey4 View Post
yea Titan is really solid forged rim for $500. Hope fit goes well, I'll get mine on order.
Even in black, the angles look good
I finally mounted them.
It’s about to rain so weather is not cooperating today, but I figured it would give you an idea of what they look like.
What size rims / offset and what tyres? Are you oem suspension with no fender rolling or camber adjustments?
M240i LCI (Mineral Grey):- M2 Door Mirrors, M2 Black Kidney Grills, Lower grille inserts, MP Exhaust, Dinan Carbon Fibre CAI, hot climate intake elbow
      08-30-2020, 03:16 PM   #156
4Hockey4
Drives: Pinto
All the info is in pages 5-7
But its Titan 7 TS5, 18x8.5 ET 44 with 235/40 square. its the 5x120mm 08X 04'-11' selection on Titan site. (they are being made, waiting on mine, plan on end of September if you ordered now, estimate)
He did no spacer but was REAL close, said 3mm spacer was solid and 5mm worked and he liked flush look more.
(I'm not sure he checks this thread much anymore.)
I'm doing same and running 3mm up front, and nothing in back
Si-M240i136.50
      08-30-2020, 03:19 PM   #157
Si-M240i
United Kingdom
137
Drives: M240i LCI
So square, not staggered wheels but staggered tyres?
      08-31-2020, 06:33 PM   #158
Devil doc
Drives: M240ix
Sorry, I haven’t checked this thread in a bit. My tires are 235/40/18s (square) and I run a front 3mm spacer/rear 5mm spacer. The wheels are 18x8.5” et44 square aswell.
The rear spacer is not necessary, but I think it makes the fitment a little more flush and thats the reason I run it.
The front did fit without the 3mm spacer; however, it was VERY close to the strut, so I chose too run a 3mm spacer for added room against the strut. My car is on a stock xDrive suspension, and I do not have any other suspension or body modifications. I have not encountered any rubbing at all during the Last couple of months I’ve driven this configuration. Hope that helps.
Si-M240i136.50
      10-06-2020, 10:12 PM   #159
Rotorav8r
Drives: BMW M235i ‘16
Another data point
First post:
I’m running 18x8 ET34 stock suspension and Ventus RS4 235/40’s square. Never had an issue with rubbing.
Added Millway camber plates with poly bushings. Really like them. Put in -2.5 deg camber front 0 tow and -1.75 dog rear 1mm tow. Makes much nicer at track.
Next is 245’s square.
      10-10-2020, 04:21 PM   #160
4Hockey4
Drives: Pinto
Titan 7 TS5's in, PS4S ordered. Long haul but it'll be worth the wait.
      10-10-2020, 06:07 PM   #161
aftercorbu
aftercorbu's Avatar
Drives: 20 M2C, 20 S3
Nice!
      10-10-2020, 07:12 PM   #162
Devil doc
Drives: M240ix
Im so happy you finally got them. Humble suggestion...get them ceramic coated before you mount them, specially if you still run the stock pads. The dust is awful and the black wheels will show every bit of it. At least with the ceramic coating, it'll be easier to clean
      10-10-2020, 07:26 PM   #163
4Hockey4
Drives: Pinto
Have no idea where to get that but I'll look into, going DS2500 soon. Also not a DD, like 5k a year, and hand washed weekly lol
      10-10-2020, 09:08 PM   #164
4Hockey4
Drives: Pinto
Since they are new, wonder if this is something I could do myself. Reached out to Titan to see if they had a preferred provider, maybe I could ask in detail section
      10-11-2020, 09:45 AM   #165
4Hockey4
Drives: Pinto
Titan rec'd C5 by Gtechniq. Gets solid reviews, going to order 30ml, and do 2nd coat on face
https://www.amazon.com/Gtechniq-C5-W...p?ie=UTF8&th=1
      10-11-2020, 07:30 PM   #166
dradernh
dradernh's Avatar
4413
Drives: 2017 M240i
Smart move, IMO. I recently had a set of wheels coated with a professional-level product and look forward to seeing how it does compared to what I've been using.
I've been running Hawk DTC-70s. They're a hardcore race pad, extremely dusty, have a high metal content, and I generally spend two hours cleaning the wheels.
That time includes taking all four wheels off the car, cleaning every last part of each wheel, and then putting the wheels back on. I'm an old guy and don't doubt that others would get it done faster.
Still, a good deal of that time is spent scrubbing the wheels with fairly aggressive brushes. Otherwise, I've been unsuccessful in removing all of the brake dust.
Until now, I've coated the wheels after each cleaning with SONAX Wheel Rim Shield. Before I started doing that, the job was much more difficult.
I'm hoping the ceramic coating I had the shop put on the wheels makes cleaning easier. I'm also putting a BMW pad back on the car, too – which should help, a lot.
      10-23-2020, 05:09 PM   #167
4Hockey4
Drives: Pinto
Super stoked to finally have them on. Need to change/fix gray stem, but the PS4S is a completely different tire then crappy run flats. And glad I did Gtechniq G5 wheel coating/sealant.
Did 3mm front, almost flush, zero rub. No Spacer in rear - think I like where they sit.
Titan 7 ts-5 Black, F8X 04-11 Wheels. 235/40r18 square.
DLag30103.50
      03-23-2021, 03:19 PM   #168
4Hockey4
Drives: Pinto
Think a few other folks have looked into and/or bought Titans, post here so folks can see. Cheers
      03-27-2021, 04:33 PM   #169
4Hockey4
Drives: Pinto
IamJovonW
      03-28-2021, 12:32 AM   #170
IAmJovonW
Drives: BMW M235i Coupe
IamJovonW
Very nice
      07-08-2021, 08:00 AM   #171
Ajowhan
Drives: m240i 'vert
Looks like Titan only listed a square set for our platform, has anyone gotten another set to fit on ours? Or is the 8.5 et 44 one size fit all tires size that fits on our car?
245s square or staggered front 235 rear 255 is what Im thinking of.
