2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack 19'' BBS CI-R
      10-07-2016, 09:28 AM   #23
paul_italy
Drives: 228i
here is my setup
Tyre PSS
front 8x19 +5 mm spacer 225
rear 9x19 245
Unfortunately in Italy we cannot use different tire size wrt what has been homologated by BMW
ABPReader215.00
SPJR35.00
      10-07-2016, 11:15 AM   #24
Kasteel
Drives: BMW Z4M MY07
Originally Posted by Tano22 View Post
any other pics of this setup? Does anyone have any experience installing these wheels according to the Dinan specs?
Specifications:
Front Wheel
Size: 19" x 8.0" et45
Weight: 27.2 lbs
Recommended Tire: Michelin Pilot Super Sport or P-Zero Corsa – 235/35-19
(For other tires see note below)
Rear Wheel
Size: 19" x 9.0" et48
Weight: 24.9 lbs
Recommended Tire: Michelin Pilot Super Sport or P-Zero Corsa – 265/30-19
Anyone running similair sizes?
      10-07-2016, 12:25 PM   #25
Tano22
Tano22's Avatar
148
Drives: 2024 BMW M4 Competition XDrive
Can't tell from the Dinan site if this would require spacers or not.
      10-07-2016, 01:22 PM   #26
AlpsRider
AlpsRider's Avatar
2865
Drives: M2 Competition, LBB, 6MT
I don't think that they would require spacers, the wheel should only protrude out 6.3 mm on each side. http://www.willtheyfit.com/index.php...h=8&offset2=45
Many people want a more aggressive stance, that would be the reason for spacers.
Tano22147.50
      10-07-2016, 02:08 PM   #27
Tano22
Tano22's Avatar
148
http://www.willtheyfit.com/index.php...t2=48#isPage=1
this too close to the strut for the rear? (I have RWD all season tires, so it's not a staggered setup)
      10-07-2016, 03:43 PM   #28
AlpsRider
AlpsRider's Avatar
2865
No
Tano22147.50
      10-08-2016, 02:51 AM   #29
Joe240
Joe240's Avatar
Drives: 2021 C8 Corvette 1LT
My understanding is the BBS requires 5mm spacers in the front to clear the suspension. The rear don't require spacers.
I'm running 19x8.5et39 19x9.5et44 with a 235/265 setup. No rubbing, stock suspension. Dropping would definitely rub the backs though. Front might rub but could roll the fender to fix that. Front on mine has minimal clearance (maybe 2-4mm) from the suspension. Rear has a decent amount of space still.
      10-08-2016, 06:32 AM   #30
AlpsRider
AlpsRider's Avatar
2865
The CI-R wheels are 6.3 mm closer to the strut than stock without spacers.
http://www.willtheyfit.com/index.php...t2=45#isPage=1
This calculator shows your wheels would be 6.7 mm closer to the strut than stock.
http://www.willtheyfit.com/index.php...t2=39#isPage=1
So the strut clearance should be almost the same.
      10-08-2016, 12:01 PM   #31
Joe240
Joe240's Avatar
You're right, I looked back where I thought I saw it and the guy was running 8.5s not 8s on the front with et45. He needed the spacer.
      02-08-2017, 09:29 AM   #32
Tano22
Tano22's Avatar
148
Welp. Pulled the trigger on the CI-R (black). They should get in in a couple weeks.
19x8 et45 front
19x9 et48 rear.
I'll go 235/35-19 in the front and 265/30-19 in the rear.
      02-08-2017, 12:28 PM   #33
Blete
Blete's Avatar
Drives: N54 335i
Originally Posted by ABPReader View Post
For the option B & C, maybe the front wheels will look more concave than the rear. If it is the case, the car will look weird. I think that the option A is the best.
The combo 19x8.5ET35 and 19x9.5ET40 is probably the best looking, but it requires some camber adjustements.
I have tried BBS CH in 19x9.5ET40, as the car is my daily I don't want to modify the camber or I don't want any rubbing.
Dude, what tyre size are you running on the rear??
      02-09-2017, 05:26 AM   #34
ABPReader
Deserter
ABPReader's Avatar
No_Country
215
Drives: BM&W
265 r19, I don't remember the height but probably 35
Blete1.00
      02-11-2017, 09:39 AM   #35
Tano22
Tano22's Avatar
148
Just got them in. Now just need tires and mounting.
ABPReader215.00
      02-13-2017, 11:25 AM   #36
Kasteel
Nice, countdown started!!
      02-13-2017, 12:29 PM   #37
Blete
Blete's Avatar
Drives: N54 335i
Thanks!
      02-18-2017, 05:23 AM   #38
AlpsRider
AlpsRider's Avatar
2865
I have these on order as well. I've ordered Michelin Pilot 4 S tires in 235/35/19 and 265/30/19. They are schedueled to be delivered the first week of March. I can't wait to get bigger rubber under this car. The nanny constantly works overtime with the current stock tires.
      02-23-2017, 08:42 PM   #39
Tano22
Tano22's Avatar
148
Update: Bought the tires. Michelin Pilot Sport 4s
235/35/19
265/30/19
Waiting for the shipment to arrive. No idea when that will be.
      03-02-2017, 07:47 AM   #40
Tano22
Tano22's Avatar
148
235/35/19
265/30/19
Update, i think someone else was in the same boat as me with respect to waiting for these tires. Just spoke with Tirerack and unfortunately, looks like the earliest Michelin will be getting the tires to Tirerack is 3/24. The wait continues.
      03-02-2017, 01:40 PM   #41
AlpsRider
AlpsRider's Avatar
2865
Yep, mine are on the same schedule. I'm having them mounted and balanced before delivery. I hope that isn't a mistake, they have the latest touchless equipment.
      03-08-2017, 09:17 AM   #42
AlpsRider
AlpsRider's Avatar
2865
Apparently the 265s are available now from Tire Rack at one of their warehouses, just not the one in Nevada where mine are being mounted and balanced for free. So if you are just ordering tires your wait is probably over. I have to wait till the 25th :-(
      03-08-2017, 09:27 AM   #43
Tano22
Tano22's Avatar
148
My availability date changed to 3/9/17, so maybe mine are being shipped from that warehouse you speak of. Here's hoping that tomorrow I get a shipment notification.
      03-08-2017, 09:45 AM   #44
AlpsRider
AlpsRider's Avatar
2865
When I called them they said that 6 were already spoken for and they were getting 10. Yours were probably part of the 6. Do you plan to use 5mm spacers in the front or leave them as is? Some people have said that they are necessary, but I've done the calculations and I think that there is plenty of room in the front. Without the spacers, the scrub radius is perfect.
https://www.wheel-size.com/calc/?whe...cl=57mm&sr=0mm
Tano22147.50
