02-12-2016, 10:46 AM | #23 |
Rep 1,422
02-12-2016, 11:58 AM | #25 | |
Rep 1,503
I am. I'm cutting it really close both front and rear, but I didn't need any trimming. 265 and 235 MPSS
FBO M235i r
F80 M3 |
02-12-2016, 06:02 PM | #27 | |
Rep 1,503
18x8.5 ET45 with 5mm spacer 18x9.5 ET62 with 15mm spacer 235/40 and 265/35 MPSS
FBO M235i r
F80 M3 Last edited by ocN55; 02-12-2016 at 06:13 PM.. |
02-12-2016, 06:33 PM | #28 |
Rep 1,422
Oh snap LA. Ok my car won't be out there anytime soon.
I think I'll try the 5mm and 10mm spacers in the front and rear, respectively. Did you get a wheel stud conversion or get longer wheel bolts? Thanks! |
02-12-2016, 06:43 PM | #29 |
BMW Lover
122
Rep 251
[QUOTE=ocN55;19379723]Mywifes335 is running the same width and compound of tire...
indeed my bad i confused him with another member on Hankook , M-tavo his car looks sick as well |
02-12-2016, 08:19 PM | #30 |
Rep 1,422
All good. I'm running PSS all around indeed.
Had Hankooks on my wife's 335....not happy with them in wet or on track. PSS has been one of the best summer tires I've had since PS2. Falken Azenis Sports (discontinued) were great too. |
02-12-2016, 08:31 PM | #31 | |
Rep 1,503
I got longer bolts
FBO M235i r
F80 M3 |
02-12-2016, 08:40 PM | #32 | |
Rep 1,422
I'll check them out. Why are 10mm spacers a bad idea? Did you get H&R hardware? And when you put the spacer on did you have to do anything to make them fit properly? Sorry for all the questions. Your experience will be my wisdom...to not make mistakes in buying the wrong stuff. Thank you! |
02-12-2016, 09:28 PM | #33 | |
Rep 5,262
The 10mm Spacer Dilemma 10mm wheel spacers are one of the most common spacer sizes out there. However, what a lot of people don't realize is that a 10mm size is not a true fitment on any BMW. It's considered a "tuner" fitment, meaning some extra thought is usually required to correctly install them. Only with the right combination of parts will a 10mm spacer fit without a vibration or other fitment issues. Factory Hub Lips Are Greater Than 10mm The depth of the lip on the car where the spacer will rest will vary. The available lip space may be 11mm and a 10mm spacer with its own hubcentric lip cannot physically fit. The spacer will bottom out on the lip instead of on the brake hat, leaving a gap between the spacer and the rotor hat. The biggest reason for this is the thickness of the rotor hat. The thickness varies by manufacturer and design. A thinner hat (such as used with aluminum Euro Floating rotors) will leave more lip protruding and make the problem worse. Most spacer manufacturers add an extra chamfer, or shoulder, to push the hubcentric lip further out. The extra chamfer clears any extra part of the stock lip. The other way to get the spacer to fit is to shave the stock lip with a metal file. While not the most elegant solution, it works. |
02-12-2016, 09:43 PM | #34 |
BMW Lover
122
Rep 251
02-12-2016, 09:45 PM | #35 |
Rep 1,503
yup
FBO M235i r
F80 M3 |
02-12-2016, 10:02 PM | #37 | |
Rep 1,503
Thanks for your kind words
FBO M235i r
F80 M3 |
02-12-2016, 10:04 PM | #38 | |
Rep 1,422
02-12-2016, 10:16 PM | #39 | |
Rep 5,262
Look at the Misc notes on that same link -All BMWs use hubcentric wheels. When mounted to the car, the wheel rests on a lip instead of the wheel bolts or studs. The lip is usually 9-10.5mm in depth. The lip contributes to the strength of the wheel and the wheel cannot safely be used without a lip. The wheel bolts are not strong enough to support the weight and loads generated through the wheel. Any spacer smaller than 10mm will not have a hubcentric lip on it. It's physically impossible since the spacer slides over the existing lip but is not thick enough to take the lip's place (the standard lip still protrudes through the spacer). With a 9mm lip, a 5mm spacer will only leave 4mm of stock lip left for the wheel to rest on. This is important to keep in mind when considering your wheel/spacer setup. A wheel with a beveled edge on the back will not adequately rest on the lip, resulting in a vibration because the wheel is not truly centered on the hub. For most 5-lug BMW applications, Turner Motorsport offers a hub-extender. This takes the place of your hub's dust cap and adds an extra 10mm of lip for the wheel to rest on. Using the example above, instead of 4mm left over on the lip, you now have 14mm of lip to use. With the hub extenders, you can also change spacers around without fear of losing lip space - it can be used with a 3mm, 5mm, 8mm, or 10mm spacer. Spacers with their own integrated hubcentric lip are: 10mm*, 12mm, 12.5mm, 15mm, 18mm, 20mm, 25mm, and 30mm. * -- Note that H&R and Turner Motorsport each make a 10mm hubcentric spacer but due to interferences between the spacer and lip, it's best to leave this to specialized applications. The lip on the car must be shaved down so the 10mm spacer will fit flush on the rotor hat. |
02-12-2016, 10:24 PM | #40 |
Rep 1,422
Hmmm...so 12mm spacer OK. 5mm spacer needs the hub extender.
Yeah the hubcentricity of BMW rolling stock designs got me in trouble with Enkeis before...had to install these rings. |
02-12-2016, 11:56 PM | #42 |
Rep 1,084
02-13-2016, 12:39 AM | #43 |
Rep 1,503
Yup check them out here. http://www.2addicts.com/forums/showthread.php?t=1215899
Side note, I tried to reach out to you on facebook regarding tuning advice.
FBO M235i r
F80 M3 |
Mr Carrots766.50 |
02-13-2016, 02:14 AM | #44 | |
Rep 444
Was pretty busy today running around and still no rubbing or any issues. Will snap some tomorrow.
Quickest Stock Turbo F8x In The World
