02-02-2016, 06:14 PM | #1 |
BMW Lover
122
Rep 251
265 Rear PSS ?
Hello Guys!
i'm Wondering if there is any legit wheels setup that takes some fat 265's rear (18 or 19 ) with PSS that requires no fender rolling nor any spacers on stock suspension . Closest thing i found is this guy but he has Spacers : http://www.2addicts.com/forums/showthread.php?t=1215899 Thank you |
02-02-2016, 06:44 PM | #4 |
BMW Lover
122
Rep 251
02-02-2016, 08:17 PM | #6 | |
Rep 1,503
Just put some antiseize prior and they will come off no problem. My advice to you would be to get around a ET47 or ET48 wheel for a 265 tire (though I'm not sure if those offsets are mass produced, hence why I got spacers). 18x9.5 et50 will rub on the shock cover for sure, which isn't a big deal but you said you don't want to trim anything. Also, consider getting a 255 tire instead, I was actually surprised by how wide the PSS run; the 265 has some pinch on my car. A 255 PSS on a 9.5 wheel seems to be the ideal fit, I just got the 265 to see if it can be done. Inner and outer clearance is very very tight, don't try anything crazy with offsets unless you're willing to experiment (ie fender rolling, alignment adjustment, etc.)
FBO M235i r
F80 M3 Last edited by ocN55; 02-02-2016 at 08:29 PM.. |
02-02-2016, 09:41 PM | #7 | |
BMW Lover
122
Rep 251
02-03-2016, 01:01 AM | #8 |
Rep 1,503
I didn't realize how true this statement was until I got the tires on. Still a good fit, but some might prefer a performance stretch for more initial response. I just wanted more peak grip.
FBO M235i r
F80 M3 |
02-03-2016, 03:40 AM | #9 | |
Rep 1,091
This would be such an obvious solution of adding some rubber that if almost seems suspicious noone reported it so far. Please confirm or deny!
previous: 2003 E46 330i SMG
02-03-2016, 04:05 AM | #10 | |
Rep 1,503
And you're correct, rear offset would be adjusted to 47mm.
FBO M235i r
F80 M3 |
02-03-2016, 07:25 AM | #12 |
Rep 1,184
[QUOTE=M235Montreal;19323477]Hello Guys!
i'm Wondering if there is any legit wheels setup that takes some fat 265's rear (18 or 19 ) with PSS that requires no fender rolling nor any spacers on stock suspension . Can fenders be rolled on our car? I wouldn't mind paying a reputable shop a little bit to do this if it help my fit 265s. I did feel up in the fender well quickly and it didn't feel like there was much of a lip there? |
02-03-2016, 07:31 AM | #13 |
Rep 1,091
[QUOTE=jmwilson125;19325953]To rub or not to rub can be a matter of a tenth of millimeter...
02-03-2016, 01:06 PM | #14 | |
Rep 1,184
[QUOTE=moldcad;19325981]
But I was just wondering if there was an actual lip to roll because it didn't feel like the lip on other cars. My friend said you can't roll his g35 because they come with the lips already flattened up. Also don't drive my car during the week so I cant go check untill the weekend |
02-03-2016, 05:30 PM | #15 |
Rep 444
You can't roll the rear fender. There is no lip.
YOLO89 What is the tire sizing? 255/35 or 255/30? Also, what you running on the fronts?
Quickest Stock Turbo F8x In The World
02-03-2016, 10:23 PM | #16 | |
Rep 2,494
02-04-2016, 05:35 AM | #17 |
Rep 444
I'll let you guys know how my set up works early next week.
19x8.5 +35 235/35/19FR 19x9.5 +40 265/30/19R
02-04-2016, 05:40 AM | #18 | |
Rep 444
Just be safe and don't roll with a 2 big guys in the back.
02-04-2016, 08:39 AM | #19 | ||
Rep 2,494
I saw another 2 at the local meet this past weekend with 275 but didn't get the chance to speak with the owner about how it was. |
02-04-2016, 11:00 AM | #20 |
Rep 1,184
02-04-2016, 01:20 PM | #21 |
Rep 1,503
Really aggressive fitment, that's almost for an F30. I would expect that you will need to roll your fenders, certainly if you are lowered.
FBO M235i r
F80 M3 |
02-04-2016, 06:00 PM | #22 |
Rep 444
I've been doing some calculators and think it should we fine. Just got the rims today, waiting on the tires. =D
