01-07-2015, 10:50 PM | #67 | |
***** noob
1370
Rep 10,479
3-5" is nothing here in new england. We havent had a snow storm yet but your review is scaring me
2006 325xi (Sold)
01-08-2015, 08:04 AM | #68 |
Rep 862
Drives: '19 M2 '21 X5
I am rocking the OEM recommended TS830P's and have been fairly impressed( i had low expectations, i got RFT's because my wife drives the car sometimes and it gets to cold in the winter here to be screwing around with a tow). Got stuck once (literally an ice rut that both rears were in and i couldn't bounce over from street parking). Which isn't really stuck imo. I got out of the car and the weight transfer of my wife getting into the drivers for me to "push" was enough for her to get out.
Just drove to work in pretty sloppy conditions ( got 7-8 cm overnight on top of the foot we have received over the last week) without a hiccup. The DSC is REALLY good at keeping the car straight. If they are on and you try to initiate a power slide in the snow. No dice. DTC is much more hoonable and DSC off mental. |
01-08-2015, 08:55 AM | #69 |
***** noob
1370
Rep 10,479
So when should we turn off DSC (hit button once)..When you're stuck? We shouldnt be driving around in the snow with DSC off (DTC activated)?
2006 325xi (Sold)
01-08-2015, 09:00 AM | #70 | |
Rep 862
1 Button press will still rob power when sensing slip but to a lesser degree. Sport plus is actually fairly useful so long as you are comfortable with the sharper throttle and minimal stability control. |
06-10-2015, 09:07 AM | #71 |
manchild
64
Rep 67
Thanks for the side profile shot! If that's what the 17" SR's look like then I'm sold! I have this winter tire/wheel set up planned for my white M235xi as well. I was going to get the 18" rims but why spend the extra money? The 17's look good.
06-18-2015, 02:35 PM | #72 |
Rep 8,942
I am literally ordering a second set with a higher profile PSS summer tire to run in the warm months as we speak. Look better than stock, easier to clean, better quality wheel. I am sick of repairing the BMW wheels after every little bump with the low profile tires.
06-20-2015, 05:56 PM | #73 |
Rep 6,939
Drives: 2018 M2 AW DCT
06-21-2015, 06:30 AM | #74 | |
Rep 596
I have the 18" SRs as my winter set up and poke is very minimal. They are more or less flush and i think they actually give a better stance than stock. Tyres are 225/40/18 Pilot Alpin 4s. Don't currently have any side profile shots though. Last edited by allthatisntnow; 06-21-2015 at 06:44 AM.. |
06-24-2015, 10:51 AM | #75 |
For Pony!!!
16
Rep 96
Do you have any picture of the rear brake clearance? I just got my new M235i xdrive and I tried the old 17x8 I had on my 135i. I can't stick a finger between the barrel and the caliper, and a headphone cable (3mm) barely makes it.
'15 M Sport 328i xDrive | EB/CR
Previous cars: '15 M235i xDrive | AW/Bl | MP Exhaust | MP Grills '10 135i M Sport Pkg | JB/Beige | BMW Performance Grills | Blackline LCI Taillights |
06-24-2015, 03:37 PM | #76 |
Rep 596
You can easily fit your finger between the caliper and the wheel on the 18" version of these. 17" clears the brakes front and rear fine too if thats of any indication. Those ones you've pictured just seem to have a narrow barrel for the size of wheel. But whether you clear by 3mm or 3cm, it doesn't matter as they aren't going to contact unless you wreck the wheel. Maybe get the balance weights mounted on the inside too if it helps peace of mind.
12-27-2015, 01:17 AM | #77 |
Rep 16
12-27-2015, 09:34 AM | #78 |
Rep 8,942
No I believe it's 56mm if memory serves but call BBs to confirm. eBay blank caps then metal stickers. Went back to BBS caps they didn't hold up as well as I would have liked. I don't believe BMW makes a cap that fits but you can find Alpina that does.
12-30-2015, 10:19 PM | #79 |
BMW Lover
122
Rep 251
I bought the Same Exact Setup as you, waiting for my car to come in few days, you used centring Rings as well right ?
01-17-2016, 03:37 PM | #80 |
Rep 204
Bem, they look great and the color really compliments your car. I'm probably going to buy the lighter colored version of the same wheel. How do you like them? Did they feel heavier than the stock set-up when you changed them?
01-17-2016, 06:19 PM | #81 | |
Rep 8,942
01-20-2016, 10:19 AM | #82 |
Rep 1,931
BBS caps, or carbon fiber roundels would look best IMO.
www.nybmwcca.org
01-20-2016, 10:58 AM | #83 | |
Rep 8,942
