2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Wheel spacer testing - 5mm, 10mm, 12mm, 15mm
      02-11-2017, 08:51 AM   #111
So, 15mm is the new sweet spot for the OEM 18's?
      02-12-2017, 08:44 AM   #112
braindfect
braindfect's Avatar
Drives: 2015 M235i
I have a complete set of 15mm from BMS (burger), if anyone is interested.
They are brand new, never installed. I bought them, but then jumped on VMRs sale and moved up to 19s so I have no use for them now.
      10-04-2017, 02:51 PM   #113
AlexM240i
Drives: M240i
Originally Posted by pikcachu View Post
Got mine on... 12mm all around...
Reviving this post, what's your experience with 12mm all around? Any issues ? Vibration at high speeds? Abnormal wear of the wheel bearings ???
I want to install spacers in my M240i with 19' M Performance Wheels with stock suspension and stock brakes.
I want a sutil improvement in the stance since those M Performance Wheels are everything but concave (pretty straight).
BMS recommended me 10mm front and 12mm rear...
What do you think ?
Thanks.
      10-04-2017, 07:37 PM   #114
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
What do you think ?
Thanks.
No issues so far.
You could do 10 and 12. You will barely notice any difference between 10 and 12
Either one should work
AlexM240i101.50
      10-05-2017, 09:55 AM   #115
XutvJet
I haven't added spacers to my M235, but I did add new wheels 18X8 all around vs the stock 18X7.5 and 18X8 setup. The new wheels have 10mm more offset so it's just like running 10mm spacers. What I've noticed is that the car are much more sensitive to tramlining from ruts in the road. Overall, if the road has ruts or is bumpy, the car can be more of a handful as the suspension, especially the rear, has far more tendency to steer itself. It's proof of just how design BMW considers in their suspension and how operating the suspension outside of the designed parameters can have negative consequences. Keep this in mind when running spacers.
AlexM240i101.50
      10-14-2017, 12:59 AM   #116
acdapast
Drives: BMW M240i
Lightbulb
Originally Posted by Taunto View Post
15mm all around X-Drive on Dinan Springs
No rub issues and love how the car looks and sits.
Can I also use 15mm all around with the 2017 M240i xDrive wheel setup?
OEM Wheel Specs:
7.5Jx18 ET45 225/40ZR18 FRONT
8Jx18 ET52 245/35ZR18 REAR
Thanks!
      10-14-2017, 12:08 PM   #117
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
I run the stock 18" staggered set up with 12mm front and 15mm rear. no lowering on stock m sport suspension.
perfect fitment
2014 M5
1990 E30 318i Touring
1999 E38 728i -sold
M235i - sold
Activehybrid 5 - sold
AlexM240i101.50
      11-20-2017, 12:40 PM   #118
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
not sure how good this photo is.
shows front only I'm afraid.
2014 M5
1999 E38 728i -sold
M235i - sold
      11-27-2017, 11:58 PM   #119
icycoldd
Drives: AW M240i
Anyone running H&R with the BMS 12mm spacers all around? I have H&R springs and looking to see pictures of this setup.
      11-28-2017, 10:13 AM   #120
AlexM240i
Drives: M240i
I just ordered 12mm all around from BMS. Awaiting delivery to take some pictures....
      11-28-2017, 06:25 PM   #121
icycoldd
Drives: AW M240i
Thanks but I went ahead and just ordered VMR V703's lol. Something about the stock wheels didn't sit right with me anyways.
AlexM240i101.50
      12-17-2017, 06:09 PM   #122
gvstone
Drives: 2020 M2 CS / 2013 135i M Sport
Motorsport Hardware... great vendor!
Just a note after buying studs and spacers for my M240ix from Ryan. Great to help with your needs and helps you get what you should have!!
Excellent product also!!
      03-13-2018, 02:26 PM   #123
r0b3r
Drives: Bmw F
Hello, I have bmw no xdrive with springs h & r and rims m461 18 ", what would be the best combination to be perfect? ​​12mm front and 15mm back? Or some other measure? I will buy H & R or EIBACH spacers
      03-14-2018, 09:28 PM   #124
SwallowedABug
Drives: 2017 M240i xDrive
Spacer & Spring Config
2017 M240i with stock wheels and tires running BMS 12mm front and 18mm rear. Lowered on H&R springs. No rubbing--but have yet to stick a 200lb weight in the trunk or carry passengers in the back seat Did load the back with two full suitcases and had no issues.
Name:  cu long side.jpg
Name:  rear sidelong.jpg
