2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Coding edc on m240i
      04-10-2017, 07:58 PM   #1
SlowM240i
Drives: M240i
Coding edc on m240i
So I'm pulling the trigger on some coilovers pretty soon. If I code out my edc would I still be able to use comfort, sport and sport + for throttle transmission and steering feel? Just not dampening
I've been looking everywhere thanks
      04-10-2017, 08:01 PM   #2
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
yes
      04-10-2017, 08:13 PM   #3
SlowM240i
Drives: M240i
That was quick lol appreciate that didn't want to spend 4000 on the plug and play coils
      04-10-2017, 09:20 PM   #4
x233
Ukraine
284
Drives: M2C, M235xi
pikcachu, do you think, or do you know, if coding out would leave the variable sport steering function intact?
      04-10-2017, 11:15 PM   #5
pikcachu
pikcachu's Avatar
1399
It should, it's like the M2 where the suspension is not adaptive but everything else is the same, throttle, steering, modes etc.
Remove 2VF from FA/VO and then VO Code the DSC, KOMBI, ICM, and HU_NBT
http://f80.bimmerpost.com/forums/sho....php?t=1163342
x233284.00
      04-11-2017, 07:44 AM   #6
x233
Ukraine
284
Drives: M2C, M235xi
Thanks.
      04-11-2017, 09:19 AM   #7
SlowM240i
Drives: M240i
I've also read that once I code it I can't let the dealer update anything? Is this true?
      04-11-2017, 10:45 AM   #8
pikcachu
pikcachu's Avatar
1399
Well you might have to re-code it if they flash your car or alternative you can write the change to the FA so even if they flash the car it should flash with the updated FA and keep the disabled adaptive suspension
      07-20-2018, 06:51 PM   #9
TwistedX
Really Twisted
Drives: 2015 M235i F23 8AT
Thread revival, I did the coding but looked at the F80 post and they say you have to unplug the EDC module in the trunk. Where is it and what does it look like?
2021 Jeep Gladiator Rubicon
2015 BMW M235i F23 - Sold
      07-20-2018, 07:26 PM   #10
tyler.genter
Drives: 2018 M240i
I just did it today actually and it will allow you to use all functions if you code it out. Keep in mind depending on how low you go you may feel a little more rear body roll, then expected.
      09-02-2018, 11:38 PM   #11
SP_F80M3
Drives: F80
Do you mind posting up the steps on how to code it out? And if we really have to unplug the EDC in the trunk?
      09-09-2018, 11:23 PM   #12
EVEda235i
Mr. Clutch
EVEda235i's Avatar
Drives: 2015 M235i
2011 BMW 335i  [9.50]
+1 I'm stuck after deleting 2VF. Can't seem to find the kombi, edc, etc to V0 code them
Quiet M235i
      09-09-2018, 11:30 PM   #13
pikcachu
pikcachu's Avatar
1399
How to VO code
Connect => Read FA => Activate FA => Read SVT (VCM) => Right-Click on ECU you want to code i.e. HU_NBT (the ECU itself not the underlying CAFD) => Select CODE.
Step by step VO code guide sample for TPMS decoding https://www.2addicts.com/forums/atta...9&d=1454548372
      09-13-2018, 08:09 AM   #14
EVEda235i
Mr. Clutch
EVEda235i's Avatar
Drives: 2015 M235i
How to VO code
Step by step VO code guide sample for TPMS decoding https://www.2addicts.com/forums/atta...8;d=1454548372
How to VO code
FINALLY got it! So nice to have all the modes back again. Thanks pikcachu
Quiet M235i
      09-13-2018, 01:37 PM   #15
pikcachu
pikcachu's Avatar
1399
AmuroRay2275.00
      09-16-2018, 07:21 PM   #16
tyler.genter
Drives: 2018 M240i
Yo my bad bro I never actually get on this thing but the link that the other guy applied is definitely the way to go. To be honest I had a local shop do mine's.
      07-24-2021, 12:56 PM   #17
Jamesjedi
Jamesjedi's Avatar
Drives: NA
Old thread, I know
Can the code be easily revered?
"Well you might have to re-code it if they flash your car or alternative you can write the change to the FA so even if they flash the car it should flash with the updated FA and keep the disabled adaptive suspension"
Is this a simple thing to do? I honestly have know idea.
      07-24-2021, 09:09 PM   #18
pikcachu
pikcachu's Avatar
1399
Originally Posted by Jamesjedi View Post
Old thread, I know
writing the FA probably takes 30 secs or so...
      07-26-2021, 10:50 AM   #19
Jamesjedi
Jamesjedi's Avatar
Drives: NA
Old thread, I know
Thanks for the reply!
      08-03-2021, 12:23 PM   #20
Jamesjedi
Jamesjedi's Avatar
Drives: NA
To be clear on this subject: I can order coilovers that are not designed for EDC ?
It sounds like it may be more desirable to not get EDC hardware and use coding with suspension not designed for EDC?
Bilstein PSS10 come in EDC and non EDC.
