05-16-2022, 12:36 PM | #1 |
Rep 1
Exhaust mods for the M240 on budget
I’m trying to modify my exhaust ton my 240i but I have quickly realized that a lot of these exhaust systems are very expensive. I was wondering if anyone had any suggestions for a exhaust, mid pipe, muffler, or muffler bypass. I would like to spend under $600.
05-16-2022, 02:35 PM | #2 | |
Rep 5,339
Save up your money and buy a used/new M Performance muffler. Period. It fits like stock, won't rust out, and has an aggressive warble and almost exotic sound. Second option would be to get a high quality ($1200) catted DP. That will give a similar sound to the M Performance muffler. Midpipes created rasp and weird noises at certain rpms. Muffler deletes cause rasp, drone, boomy, and and weird noises at certain rpms and can be quite loud.
WolfGTI688.50 |
05-16-2022, 02:48 PM | #3 |
Rep 54
Drives: 2017 M240i xDrive
Dinan midpipe is about $550. There's tons you videos on Youtube of people with the stock cat and muffler with the Dinan midpipe. Sounds pretty good IMO.
05-16-2022, 05:42 PM | #4 |
Rep 908
Save up and do it right.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD. Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r). |
05-16-2022, 06:59 PM | #5 |
Rep 164
You can:
Free - remove the plug from the exhaust valve and then zip tie it somewhere it won’t get hurt. That leaves the valve open all the time and the exhaust will be as loud as it is on startup. [Edit - read Xutv’s post, below, for corrections to this] Cheap - go to a muffler shop and have them cut out the resonators from your mid pipe and have them replace the sections with straight pipe. $$ - If possible, accumulate more money and do what the others have suggested. Last edited by SoftShoe; 05-18-2022 at 12:50 AM.. |
05-16-2022, 08:08 PM | #6 |
Rep 397
Get a 200 cell high flow downpipe and resonator delete. I have it on a 235i and sounds great, I have some sound clips I posted on the forum in an earlier thread.
If you sell your current downpipe the cost should be within your budget.
Garage:
2022 Telluride Nightfall 2016 Suzuki DRZ 400 2016 M235i Mineral Gray/Coral Red 2018 X3 M40i Alpine White/Black - SOLD |
05-16-2022, 09:15 PM | #7 | |
Rep 3,472
Not all that long ago, qualified shops would build exhaust systems (i.e., exhaust headers back) for quite a bit less than what was on offer from specialists like Dinan. That's not to knock Dinan (I've been doing business with them since 1986), or any of the other exhaust system suppliers. It's just that there may still be less expensive ways to go while still getting a satisfactory result. Total MINI & BMW should be able to help you sort through it. I don't know that our cars are so special that any of that has changed.
2017 M240i: 23.6K, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
05-16-2022, 09:37 PM | #8 |
Rep 397
Here is my 235i with a resonator delete and VRSF 200 cell downpipe:
https://www.2addicts.com/forums/show....php?t=1891199
Garage:
05-17-2022, 01:59 PM | #9 |
Rep 5,339
The reason the car is loud on cold start-up is because the wastegate is wide open to allow for a quick catalytic converter light off. Once the wastegate closes, the exhaust is notably quieter. The exhaust valve makes a very minor change in exhaust noise/volume.
