05-13-2022, 11:41 PM | #23 | |
Rep 3,241
In addition to the anti-squeal shims on the brake pads, the use of anti-squeal compound can also stop the squealing which is applied to the back of the pads. I've never had to use anti-squeal compound and just rely on the anti-squeal shims that come with the brake pads. But I also take one extra step where I lubricate the ears of the pads where it sits in the calipers or other contact points depending on how the brake pads are mounted with high temp caliper grease that are normally used for the caliper sliders/guide pins. The squealing is NOT from harmonic differences between the rotor and brake pads. |
05-14-2022, 03:59 AM | #24 | |
Rep 1,815
Can you provide a copy and paste of said tech manual? I have never EVER seen ANY BMW dealer / official garage that would resurface a rotor. It is not cost effective for them to take the time to do it. A BMW mechanic would simply check the minimum thickness and slap pads on the car if they were at or thicker than the minimum unless there is any damage visible to the rotor surface. It is the service advisors job to sell more parts therefore they will always try to upsell the parts once out of their cost. Squealing comment… uh, ok.. addressed correctly a few times above. Harmonic mismatch…. if you have surface contact you have friction, friction means stopping ability.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
Boomer 20191755.00 Ennoch2257.00 |
05-14-2022, 09:09 AM | #25 |
Rep 233
yes, but only because you are such a confident ass who needs to be put in his place.
SIB numbers 34 01 14 and 34 10 16 and what do you think the vibrations are? they can form into harmonic vibration (like a wine glass with water). and based on the properties and conditions that can change and not match the other sounds of the brakes/wheels. Each piece of metal in the world has a harmonic frequency, like a tuning fork... if you tap on a piece of metal it has a sound that doesn't change. frequency is measurable and there can be a mis-match.. why do you think there are shims and compound? they are there to counter the harmonic vibrations. so laugh all you want, believe whatever you want.. but you should really keep your stupidity and rudeness from being directed at others. Last edited by kring; 05-14-2022 at 09:17 AM.. |
05-15-2022, 04:37 AM | #27 | |
Rep 1,815
34 01 14 Discuses absorber pads on the M5 and M6 vehicles. 34 10 16 <~ I stand corrected. But also very specific to rotors with damaged surfaces (in bold on the SIB) as my statement above says. AND It is also specific that it is done only in conjunction with; A. The service is related to a customer complaint. B. The car is in for a free service/inspection So if you are paying for the repair/ service, BMW WILL recommend new rotors and WILL NOT resurface the old ones. So it is true in my statement “it is NOT cost effective” for BMW to resurface rotors if you are paying for it. And bottom line, reading is very important.
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car Last edited by david in germany; 05-15-2022 at 05:28 AM.. |
05-15-2022, 05:35 AM | #28 |
Rep 1,815
On a trciary note, oncar lathes are pretty damned cool. Too bad I can’t justify one for my tool box…
05-15-2022, 06:22 AM | #29 |
Rep 233
This has become a weird discussion, I think you took a left on your crusade and are arguing points I din’t think were disputed. I certainly don’t dispute the cost effectiveness, the recommendation by BMW or that it’s best to replace the rotors as recommended by BMW. From the beginning I clearly and only recommended a full replacement to the OP..
I have no idea how to respond to your post. |
________4158.50 |
05-15-2022, 06:33 AM | #30 | |
Rep 1,815
I did state facts and even in my post above stated that you corrected me on something. I kept my post professional. Something you really should learn to do if you plan on frequently posting here.
05-15-2022, 08:23 AM | #31 |
BMW Owner Since 1971
2257
Rep 1,407
Drives: 1964 700 Sport Cabriolet
I work at a BMW dealership and we have a portable on-car brake lathe for resurfacing rotors, particularly those that will not pass inspection due to rust. It is quite common at BMW dealerships so I'm not sure where this discussion took such an ugly turn.
05-15-2022, 09:35 AM | #32 | |
Rep 1,815
It took an ugly turn because of personal insults. I personally love to learn new information. If I am wrong about a subject, give me correct info and I am happy but some people in these days resort to personal insults and think that it makes them look better.
05-15-2022, 10:52 AM | #33 | |
2257
Rep 1,407
05-15-2022, 10:56 AM | #34 | |
Rep 1,815
Thanks for your follow up! Just wanted to add, it seems to have nothing to do with functionality but to appease the troll under the bridge.
Ennoch2257.00 |
05-16-2022, 06:33 AM | #35 |
Rep 2,808
Drives: F33 430 and F39 M35i
Depends. On my f33 with base brakes I did the rear rotors and pads at 48k. Might as well. If was easy to do. Did the front pads and rotors at 60k and a brake fluid flush. Easy and cheap to do at home.
On my f39 with M brakes, replaced the front pads at 25k. Well bmw did for free. They didn’t touch the rotors. |
05-16-2022, 07:11 AM | #36 |
Rep 1,823
I’ve gone through 3 sets of pads on my M2 with a single rotor, and about 7 track days. When I went in for service at the dealer, they said rotors still had plenty of thickness. They were pretty cracked, but still thick enough.
Go by remaining thickness, and if it’s only 1 set of pads you went through, I’d definitely check before replacing. |
DrFerry6728.50 |
05-16-2022, 10:35 AM | #37 |
Rep 2,524
i only replace rotors if they need it. whether from being below spec thickness to deep damage on the face.
a lot of places recommend replacing rotors with pads, since a lot of oem rotors are starting to be thinner than they used to be, but as long as you are within the tolerances, no issue.
DrFerry6728.50 |
05-27-2022, 09:21 PM | #38 |
1Addict
3233
Rep 7,893
I never replace rotors until they're spent, and resurfacing is a waste of money IMO, just throw on some track pads do a few hard stops and put your new street pads in, bed them, and you're gtg.
What a pile of malarkey. How much wasted money does a new set of rotors every pad change come out to?
grannyknot950.50 DrFerry6728.50 |
05-28-2022, 07:01 AM | #39 | |
Rep 25
05-28-2022, 08:10 AM | #40 | |
General
17294
Rep 18,726
DrFerry6728.50 |
05-28-2022, 09:45 AM | #41 | |
Rep 14,519
Drives: Audi S3....don't judge me
