2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications Schirmer Wing
      03-31-2022, 09:57 PM   #1
MVBUILT
Schirmer Wing
Thinking about doing a team schirmer wing on my F22. Does anyone have one on theirs? Haven't seen it on an f22 yet. I've read that it's basically the same as the m235ir wing just with smaller uprights and end plates…. Dropped photos of the wing and my build for reference
      04-09-2022, 12:47 PM   #2
Steakpizza
Drives: 320i
Here's my wing. Had a local shop install for 200$. With most of them you have to have plates/supports in the trunk to keep the wing stable or else it'll be flappy as hell. Most kits come with support plating, if not then a shop would have to weld it (costs a bit more). Good luck, should only take a few hours for install.
MVBUILT30.00
jordan24c128.00
      04-20-2022, 01:29 AM   #3
230iZTR
230iZTR's Avatar
316
I'll be joining the F82 GTS Wang Gang soon.
      05-13-2022, 04:40 PM   #4
230iZTR
230iZTR's Avatar
316
Has anyone seen data on downforce for the GTS wing when paired with the original "low" M4 mounts compared to the "high" M240iR Evo mounts? Intuition says getting it higher in cleaner air should be better, but how much better are we talking?
      05-13-2022, 06:03 PM   #5
aerobod
aerobod's Avatar
3626
A wing of that size in free air (about 0.25 square metres by the looks of it) will only generate about 140N (31lbf) of downforce at 30m/s (67mph) or 390N (88lbf) at 50 m/s (112mph).
The difference in being in free air compared within the trailing flow off the rear window is probably only about 10%, so perhaps 40N (9lbf) at 50m/s (112mph). The main thing to adjust is the angle of incidence to the flow to ensure it doesn't stall if the air flow direction is too acute to the wing leading edge.
Another consideration is that a smaller gap to a surface can actually accelerate flow, increasing the velocity across the aerofoil. Only a CFD simulation or wind tunnel measurement will give an accurate result.
Generally two bags of sand in the trunk will be more beneficial to rear axle down force than a wing of that type and position in normal road or light track use.
n55david1295.50
