2Addicts | BMW 2-Series forum Technical Topics Tracking / Autocrossing will a 40 series tire fit 228i without rubbing?
      01-18-2022, 03:42 PM   #1
matter57
matter57's Avatar
Drives: 2015 BMW 228i
I'm currently running OEM 18" wheels (8" I believe) with 245/35 Michelin 4S tires. 12mm spacer in front. About -3 front camber
New wheels are Apex Arc-8 (8.5") et45 with 5mm spacers in front - have not mounted these yet.
There are only a very few track oriented tires in the 245/35. 40 series tires offer a lot more choices but will they fit? It looks close. The 4S is 24.8" in diameter in 35's and most 40's are about 1" bigger in diameter.
Any experience running 245/40 on the 228i's? will they rub? I'd prefer to have a pretty good idea before I buy them. Thanks!
2015 228i w/track package, MCS 2 way NonRemote Dampers, new bmw long block, VRSF catless downpipe, AR Mtrsports oil pan baffle, Ground Control camber plates, Apex ARC-8 18 x8.5 wheels, ET45 with 5mm spacer in front only, Schroth Quick Fit Pro harnesses
      01-19-2022, 09:02 AM   #2
PeanuKeeyes
PeanuKeeyes's Avatar
366
Drives: E34 | MX5
I’m running 18x8.5 Apex ARC - 8 et38 with Michelin Pilot Sport AS3+ 235/40/18 square
-2 camber, no rubbing at all. I ran them at a track day and even full compression didn’t bring rubbing. I’m planning on replacing this set with the same tire in 245/40 next year.
E34 525iT 5 spd | 228i ZTR 6 spd [SOLD] | MX-5 NA 6 spd
