2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum Regional Forums USA - NY / NJ / CT / PA misfire and now car won't start
      06-06-2021, 07:23 AM   #1
Kamilnieradka
United Kingdom
Drives: BMW 220i
hello all,
new to this forum
car is 2014 bmw 220i
yesterday I was driving and all sudden I had lost of power quite significantly, so I plugged in I Carly and shows cylinder 1 misfire, injection shut off
went into garage and they changed spark plugs and swapped coils with cylinder 2 and the problem didn't jump so they said I need new injector
so they said I can drive back home but I barely made it home, this morning tried to start it but no luck, it cranks over but doesn't turn over.
just wondering if anyone might know what causes the car not fire up, it could be that injector is out that its not enough fuel pressure to start the car
      06-06-2021, 01:25 PM   #2
Maynard
Drives: 228iX & M2C
you should re-post this in the engine section - this subforum is just for people in NY area. I think you have the N20, so this would be best subforum: https://www.2addicts.com/forums/forumdisplay.php?f=531
These cars are pretty 'smart' and will shut off for self-protection due to many different reasons; most likely this is what is happening to you (can't say if it is low fuel pressure specifically, but most likely it can tell that the injector is bunk and won't let you start that way). It can be annoying, but ultimately much better than letting things go on until there is mechanical damage; sounds like tow truck time.
      06-07-2021, 01:16 PM   #3
Kamilnieradka
United Kingdom
Drives: BMW 220i
Thanks for reply mate,
So these cars know that something wrong like wrong injector and it will shut it off, one it’s been replaced how do I tell the computer that it’s new injector so it can let go?
      06-08-2021, 11:05 AM   #4
TrboMike
Drives: BMW M240ix
I assume the check engine light is on. What codes is it showing?
      06-08-2021, 11:34 AM   #5
Kamilnieradka
United Kingdom
Drives: BMW 220i
The engine light was flashing when I had foot on gas when I didn’t it stayed on
The garage swapped injector and started the car but they didnt re program the injector yet would that prevent it from starting?
If that won’t work, what could potentially be next to be changed?
Codes are 140101 cylinder 1 injection is turned off
      06-08-2021, 11:37 AM   #6
Kamilnieradka
United Kingdom
Drives: BMW 220i
The sparks and coil on that cylinder been changed as well
      06-09-2021, 06:33 AM   #7
Kamilnieradka
United Kingdom
Drives: BMW 220i
Bump…
Im getting this code, the garage changed sparks plugs coil and now injector on it and still nothing, it cranks over healthy but doesn’t start, anyone that had an issue or know how to sort it out would be much appreciated
      06-09-2021, 11:50 AM   #8
TrboMike
Drives: BMW M240ix
Could be mechanical problem (valve, ring, etc). Did they do compression test on #1?
      06-09-2021, 02:13 PM   #9
Kamilnieradka
United Kingdom
Drives: BMW 220i
No not yet mate, been in garage for 3 days and they only touched a injector lol, giving them till Friday and it’s moving into bmw specialist where I live
Hoping they will do compression test as it will stop me from worrying
      06-10-2021, 12:47 PM   #10
Kamilnieradka
United Kingdom
Drives: BMW 220i
So the garage said they replaced coil plugs and injector on cylinder 1 and now it says cylinder 4,
The car runs on and runs but it’s rough and you need to have foot on the gas to keep it alive as soon as you let go it will cut off. So they referred me to bmw specialist which I’ve been last night to talk to them.
I’m hoping its lpfp or it might be jumped timing belt?
What do people think?
      06-15-2021, 12:15 PM   #11
TrboMike
Drives: BMW M240ix
Ask a mod to move this to the engine forum. Right now you're in the new york city forum so not many people seeing it.
      06-17-2021, 12:25 PM   #12
Kamilnieradka
United Kingdom
Drives: BMW 220i
Hi update,
Cylinder 1 doesn’t have compression so they will be taking head off and hopefully they will find valve damaged as I don’t want it to be a piston ��
      06-18-2021, 11:13 AM   #13
TrboMike
Drives: BMW M240ix
Well thats not good news. Was car being beaten on at time of failure?
Is compression LOW or ZERO? Any knocking when it went?
      07-10-2021, 12:39 AM   #14
Kamilnieradka
United Kingdom
Drives: BMW 220i
They finally took the head off and it was broken piston ring think it’s due to the tune running too much power. Lucky enough the metal particles didn’t damage the side walls Replace all 4 and timing chain is 3.2k lol basically engine rebuild
I’ll add photo of the piston Name:  74624F91-D5D3-4D72-9AD4-B6EE32BB78E9.jpg
