02-05-2021, 04:32 PM | #2 |
Rep 444
Haven't done it, but looking at the offsets on their website, the 17x9.5et37 (71HP7095N67A) won't work in the back. You could probably do the 17x8et46 (71MB7080N63A) with a ~5mm spacer in front and a 17x9et46 (71MP7090N68A) in the rear if you're not real low. You'll also need hubcentric rings to reduce the bore from 80.77mm to 72.56mm unless they can do that custom as well. Might be able to do a 17x9et46 square setup with camber plates, a ~8-10mm spacer, and an inner-fender lip roll in the front.
02-14-2021, 07:51 AM | #3 | |
Rep 97
02-14-2021, 10:47 AM | #4 |
Rep 3,496
This may help: https://blog.ecstuning.com/understan...d-backspacing/.
03-29-2021, 11:04 AM | #5 |
Rep 97
Well here it is, it was a shot in the dark guess what specs would fit and it was a first time weld got an order for a 2series. But perfect fitment it is
CarbonLion33.00 |
04-19-2022, 12:33 AM | #6 |
Rep 36
What are the specs for the wheels? Also are you xdrive?
sl0w_N55
-MHD stage 2 -Jordan Carry custom e85 tuned |
05-24-2022, 04:27 PM | #7 | |
Rep 66
Sizes
What are these wheel specs? Looks awesome in the rear. I just ordered some welds for my e92.
Zachary Schneider
05-24-2022, 10:19 PM | #8 | |
Rep 97
07-28-2022, 08:51 PM | #9 |
Rep 4
Old thread so it might be a shot in the dark but what offset were these. I see they have a pair of these in a 17x9 et45 but it is 5x120.65 bolt pattern. Is that the spec pictured above?
10-22-2022, 12:21 AM | #10 |
Rep 1
10-22-2022, 06:51 PM | #11 |
Rep 97
The invoice doesn't say and I don't remember but it had 6.8" backspacing if that helps
06-19-2023, 01:33 PM | #12 |
Rep 4
