06-23-2015, 04:28 PM | #3 |
Rep 1,084
Apex Race Parts' gallery has a 2-series with 265/35r18 Nitto NT05 on 18x9.5et58 EC-7s
http://www.myapexparts.com/2014/12/1...-on-bmw-m235i/ |
06-23-2015, 04:32 PM | #4 |
Rep 986
I'm more looking for a non NITTO setup on M235.
The nt05 is a very narrow tire, compared to most high perf and extreme summer tires like Michelin PSS, Pole Position S04. etc. |
06-24-2015, 10:02 AM | #6 |
Rep 986
Not everyone needs to run a track / race tire. I drive 99% street as a DD. Michelin PSS is not inferior it's in a completely different class of tires.
This is not a d*ck session on who's tire is wider or stickier. Who is really running a 265/35/18 or tried in the past. Last edited by zipphreak; 07-11-2015 at 07:32 AM.. |
Taunto281.50 |
06-24-2015, 10:46 AM | #7 | |
Rep 1,503
06-24-2015, 11:55 AM | #8 |
Rep 986
Correct this is why i started this post as they posted some invalid information and never recalled those fitments. There is very little test/fitment information for anything beyond 255/35/18
The 265/35/18 NITTO NT05 has a 10.59" section width, as opposed to most perf summer tires is 10.7" Doesn't seem like alot but when your fitments are tight 3mm can make the difference of rubbing or not rubbing |
07-01-2015, 09:20 AM | #9 |
Rep 986
Ordered some VMR v710 wheels and they arrived today with my second choice tire
Bridgestone S04 Pole Position Fronts are 18x8.5 ET45 (235/40/18) Rears are 18x9.5 ET50 (265/35/18) Taking bets if they will fit without issues Last edited by zipphreak; 07-01-2015 at 09:33 AM.. |
Taunto281.50 |
07-01-2015, 12:20 PM | #10 | |
Rep 1,503
07-01-2015, 01:48 PM | #12 |
Rep 229
Looking forward to seeing this setup as well!
estoril_33518.00 |
07-01-2015, 08:11 PM | #13 |
Rep 986
I was able to mount them up earlier tonight, and take a ride around. No signs of rubbing yet. I have a track day on Friday to test them further.
Attachment 1236497 Last edited by zipphreak; 07-02-2015 at 05:01 AM.. |
07-01-2015, 09:13 PM | #14 |
Rep 1,503
Looking good! I hope the rears don't rub, I'd strongly consider this setup
07-01-2015, 09:33 PM | #15 |
Rep 5,262
nice.... my only issue with the setup is that it might induce some understeer on the track but for the street i bet it looks pretty nice.... to help with this set the front at higher PSI than the rear.... like 36front 34 rear... that should reduce some understeer
Also on Friday make sure after each session you check the little triangle above the WD lettering in this picture to make sure you don't roll over... If the triangle starts wearing out it means you are underinflated |
MadOzodi53.00 |
07-02-2015, 04:49 AM | #16 |
Rep 986
Thanks for the advice. I'm running the tires on wheels based on tire specs for optimal fitment. They usually give you a range, IE. 9 - 10.5" and adjusting this size will stretch or balloon the tire's section width by 0.2" for every 0.5" in wheel width.
Ideally i wanted to run 255/35/18 front and rear. Based on availability of camber plates for the F22 and me wanting to get on the track ASAP. This is an xDrive vehicle so the M4 LCA's were out of the question as another option for camber. So I chose to go the staggered route. Plus it gave an opportunity to try something that hasn't been really done much. I took alot of measurements and did a bit of number crunching (with the wheel sizing websites). I got to know way more about tire fitment; offsets, backspacing, section width, than i ever could have possibility imagined. I had issues with the rear BMW OEM caps, mine were from stock 7.5" wheels and they would not fit (stay in the center hole) for the VMR 9.5" wheels. If you look at the caps they have these plastic finger clips, and i had a couple that were the widths for the fingers, and one that was much narrower. There might be different part numbers for the wheel caps that i will check on realOEM.com. Big thanks to Mitch @ VMR wheels, he was happy to take questions and discuss wheel fitment, offer advice, and discuss 265's! Ground-Control has a v2 setup for F22 camber plates coming out this week actually. I plan on ordering a set for the front to dial in some more camber for the rubber. Unfortunately for the first track day stock camber will do, and will have to take it easy. -Paul |
07-03-2015, 04:46 PM | #17 |
Rep 986
Just an update, i did a track day today at Palmer motorsports park.. Tires worked out beautifully!! Ran tires a little higher than street about 38-40psi cold, kept me around 44-45psi hot.
07-04-2015, 01:37 AM | #18 |
Rep 1,503
07-04-2015, 12:23 PM | #20 | |
Rep 1,503
I'm just wondering if the reason you're not rubbing is because you are x-drive, I could be totally wrong though. |
07-04-2015, 01:57 PM | #21 |
Rep 6,955
Drives: 2018 M2 AW DCT
I can't tell if your 710s are gun metal or silver. They look great though.
