2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Coilovers that don't lower too much in the rear
      01-28-2022, 04:09 AM   #1
kianf22
kianf22's Avatar
Drives: 2020 BMW M240i
Anyone know if there's any coilovers that don't lower too much in the rear? Everything I see tends to have a minimum of 1-1.5" drop. My tires will rub fender if I go too low.
      01-29-2022, 01:37 AM   #2
kianf22
kianf22's Avatar
Preferred drop range would be from stock height to about an inch lower. Anything over that I wouldn't utilize, and I need to make sure I can get the rear to sit high enough.
Currently on dinan springs and bumpstops which are rated 1" drop in the rear. (Though I think it's a little more than that) Rubbing mostly on the passenger rear which sits 1/4" lower than the driver rear. The other fender has the thinnest line of rubber on the very inside, which could be mitigated with just a touch of negative camber. But again, ride height would be key here.
Appreciate it in advance! Really hard to find advice on this as there's not many that have gone my route with the car. Most people wanna dump the car as low as possible on 18s.
      02-17-2022, 08:56 PM   #3
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Yes, Ohlins R&T. Recommended drop is 20-30 mm and easily run it at stock height or higher. Most common complaint on Ohlins is that it doesn't lower enough.
kianf2264.00
Gangplank1540.50
      02-27-2022, 06:55 PM   #4
zstokes
Drives: 2021 M3 Comp
I cannot wait to bring my M240i to you, Harold. We gonna spend some money.
2021 M3 Comp / Isle of Man over Black / Carbon Ceramics
      02-28-2022, 01:26 AM   #5
kianf22
kianf22's Avatar
Could I get a price pm'd? Would love to chat about different options as well.
      02-28-2022, 12:26 PM   #6
HP Autosport
Drives: F80 M3
Come up and spend a day in Santa Barbara and we will get you all setup!
      03-03-2022, 10:51 PM   #7
jordan24c
jordan24c's Avatar
128
Drives: '21 EB 240, G87 M2 (preodered)
2021 BMW M240i  [10.00]
I'd recommend TC Klines IIRC they can exceed stock height but can also get pretty low if you so choose. I love mine!
2021 EB M240 6MT: TC Kline Camber Plates & Coilovers, Eventuri CAI, AA Catted DP, Remus Non-Res Catback, FTP CP; M Front Lip, Rockers, Mirrors, Spoiler, Interior
kianf2264.00
