12-18-2018, 12:46 AM | #1 |
Rep 12
M235i clicking/ticking noise at idle
Hey Everyone,
I’m a new m235i owner with a ‘14 6spd. I notice a clicking/ticking sound at idle when the car is in neutral. I don’t hear it cycling through gears (at least not over the engine) and when I’m idling in neutral, it goes away as soon as I press in the clutch. Reading through the forum has me believing/hoping it’s just the fuel injectors, but I wanted to get your opinions given the observation with the clutch. Thanks! |
12-18-2018, 08:03 AM | #3 |
Rep 1,931
valves, injectors. every bmw makes it after a while.
can try to change your sensors.. Not guaranteeing it will solve it, but it made my idle much quieter and car liked it. MAP and MAF(TMAP)
www.nybmwcca.org
12-20-2018, 11:10 PM | #5 |
Rep 219
Is this the same ticking issue with the hva? If so that's pretty disappointing. Had a n52 with this issue before and it annoyed me to no end. Why hasn't BMW sort this out?
12-21-2018, 01:55 AM | #6 |
Rep 105
From what I understand, the "ticking" is the direct injectors. Apparently, they all do it. Mine certainly does.
2015 M235i 6MT | Alpine White/Black Dakota | MPerformance Body Kit | 19" M-Sport 359s w/Pilot Sport 4S (r:255/30 f:225/35)
BMS JB4 w/Bluetooth| Wagner Competition IC | Wagner DP | Evolution Raceworks IC Pipes | Dynan CAI | BMS Catch-Can | Active Autowerks Axle-Back | ECS 2-Piece Rotors/Hawk HPS 5.0 Pads | Full MP Carbon/Alcantara Trim | M-Performance Alcantara/LED Steering Wheel |
12-21-2018, 06:47 AM | #7 |
Rep 772
Drives: 2015 435i grand coupe xdrive
Direct injectors are very loud. Have you ever heard an older diesel truck, basically the same technology. Though if you do hear one that is louder than the others you might want to look into getting that one changed.
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current) 2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD) 08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD) |
12-21-2018, 10:28 PM | #8 |
Rep 2,214
If it goes away when you press the clutch, it's probably just the release bearing. Pretty common among German cars and the Sachs/Bosch clutches they use.
The release bearing typically doesn't last as long as the clutch itself, and from experience I can say it's the primary reason enthusiasts change their clutches prematurely. I get it, though, the labour is the same, so why not do it all at the same time... But a clutch assembly (less bearing) should last about 2-300k kms, in theory. The bearing is simply designed to fail, and the clutch is designed to wear..
12-22-2018, 12:13 AM | #9 |
Rep 277
Drives: 2018 230i MSport
Dang I'm glad I saw this thread... mine started doing this about a month ago. I only hear it at idle and only sometimes. Usually when I'm in a closed space like parked between 2 cars or my garage. I thought it was the elite tune v2 since I had been testing it for Dinan for about a week when I first noticed it. But I installed the bypass, and it was still there. Walked all around the car with it running, and it's definitely coming from the engine but I couldn't tell where from. I feel a little better about it with so many people saying it's normal
