2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions LED turn signal flicker
      03-04-2021, 04:57 PM   #1
HootisTigglebits
HootisTigglebits's Avatar
25
Drives: BMW M240i & BMW 330e
Hi, I just installed LED front turn signals and have the flicker so I used the bimmercode app to change the setting to LED and turn the monitoring off yet I still have a flicker and warning notification. What else do I need to code?
2017 M240i - Estoril Blue
      03-20-2021, 06:04 AM   #2
icekxd
Drives: BMW M235i
Did you get CANBUS bulbs?
      03-24-2021, 10:22 AM   #3
TrboMike
Drives: BMW M240ix
Could also be a cheap LED failing.
      06-22-2021, 02:29 PM   #4
mcmoroquin
mcmoroquin's Avatar
Spain
77
Drives: bmw m2cs
a mi me pasa lo mismo , el coche es nuevo y entiendo que ya viene con led, el caso es que la función de apagado y encendido de intermitencias lo hace bien sin parpadear pero en cuanto se ponen encendido continuo es cuando hace el parpadeo
      06-23-2021, 03:05 PM   #5
TrboMike
Drives: BMW M240ix
google translator:
The same thing happens to me, the car is new and I understand that it already comes with a LED, the fact is that the function of turning off and turning on the flashers does it well without blinking but as soon as they turn on continuously is when it blinks
It didnt do a very good job
      07-07-2021, 04:40 AM   #6
bmw_fascinated
bmw_fascinated's Avatar
15
Drives: F22 228i
I also coded the voltages since the lights are pwm dimmed if the voltage is above 12V or whatever is set.
      07-08-2021, 08:34 AM   #7
Mogki
Mogki's Avatar
Drives: BMW 230XI
I'm going second the cheap failing LED idea, I had some issues before with cheap junk LEDs throwing warnings on the dash even when coded, when I pulled them out to put in decent ones I found several resisters had burned clean off the board and other parts looked melted.
Fair warning when using cheap LEDs
      10-20-2021, 04:25 AM   #8
HootisTigglebits
25
How did you code the voltages and what voltage did you code it to?
