2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions DIY: M performance steering wheel
      07-01-2017, 09:09 AM   #1
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
so went ahead and bought the M performance steering wheel for my M235i.
black alcantara with White cross Stitch with red leather 12 o'clock marker. open pore carbon fibre insert with ///M logo at the bottom.
got this for a good price doing a deal off eBay to pay direct to the dealership who was selling.
I thought the race display version was a bit too expensive really and too much hassle to fit my self.
I had done this wheel swap previously on my 5 series so this time took 30 mins and no swearing.
you need a size 20 torx driver, flat head screwdriver and a some thing to remove the main securing bolt ( can't remember the size or name of the tool )
step 1
remove negative of the battery in the boot.
step 2
removed the airbag
you need to insert the flat head screwdriver into either side of the wheel where the access hole is. you need to push in to release the springs that hold the air bag in.
with air bag popped out remove the cable
Step 3
undo the two screws holding the trim to the wheel, then there is a single screw at the bottom at the back behind where the ///M is at the base.
step 4
remove the multi function controls. There is a single screw for each side you access from the rear of the wheel. Un clip all the cabling and dont forget to remove the screw that is earthing the controls to the wheel.
Step 5
undo the main securing bolt and pull off the wheel - the plastic back will come off as well.
if you have the vibration module or wheel heating you'll have extra cabling / modules to remove.
step 6
install in reverse order.
2014 M5
1990 E30 318i Touring
1999 E38 728i -sold
M235i - sold
Activehybrid 5 - sold
      07-01-2017, 11:47 AM   #2
Guitarman15
Drives: 2015 M235 Xdrive
step 1
step 2
removed the airbag
Step 3
step 4
Step 5
step 6
Awesome thanks!
Bvt1310.50
      07-05-2017, 10:51 AM   #3
reala
Drives: 16' MG M235i xDrive
Looks really good. How much was it?
      10-08-2017, 04:51 AM   #4
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
£550
2014 M5
1999 E38 728i -sold
M235i - sold
      03-10-2018, 09:10 PM   #5
zywangjoey
Drives: White M2 6MT
Hello. I need your help. I am stuck at #2.
I have spent 1hr on those two springs with a flat head screwdriver.
Was the screwdriver too thin? Is it hard for you to pop out the airbag?
Thank you
      03-16-2018, 02:52 PM   #6
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
Thank you
did you manage?
look at the pictures with the air bag removed and you see each spring on either side of the main bolt in the centre. it is very tricky to find to press to release, but do one side and unclip the air bag, then do the other.
2014 M5
1999 E38 728i -sold
M235i - sold
      03-22-2018, 12:24 AM   #7
BSMF87
BSMF87's Avatar
Drives: M2 BSM 6SPD
Thank you
I'm guessing you already got this done but for those who are going to do this in the future I found that the spring kept slipping off the screwdriver, I used a allen key slightly smaller than the hole and removed the airbag in 30 sec.
      03-22-2018, 01:49 AM   #8
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
good one - that would be easier - didn't think of that.
2014 M5
1999 E38 728i -sold
M235i - sold
      08-24-2018, 12:00 PM   #9
chris_s1
Drives: M235i 6MT
2012 E92 335d  [8.66]
Hey, just wanted to say thanks for putting the instructions up. I just replaced my wheel using them and all went well. My wheel was heated and had the vibration piece in so there was a lot more gubbins to move over but other than that was all the same.
The big nut that holds the wheel on needs a 16mm socket to remove, if you wanted to update your original instructions.
Thanks again
      11-06-2018, 06:07 AM   #10
MichalM240i
MichalM240i's Avatar
Czech_Republic
145
Drives: M8
Hi Chris,
was removing vibration piece hard? Also - how does heated steering wheel differs from non? I'll be doing my swap in the foreseeable future (heated steering wheel for alcantara non heated) and I'm interested in hearing what's the difference between them - are there more cable connecter or?
Thanks
Michal
Thanks again
      11-06-2018, 04:15 PM   #11
BEM-S4
BEM-S4's Avatar
Yeah I used a hex screwdriver much more meat to push the spring with. That said still not a fun job. Regular wheel is even worse did the one on our F31 that was a nightmare.
      11-06-2018, 05:06 PM   #12
BEM-S4
BEM-S4's Avatar
      11-09-2018, 07:14 PM   #13
chris_s1
Drives: M235i 6MT
Originally Posted by MichalM240i View Post
Hi Chris,
Thanks
Michal
Hi
It wasn't that hard, the vibration motor just sits in a molded foam piece that easily transferred into the same space on the new wheel. There was a connector to the heated part, which I just left with nothing connected when the new wheel was put on. I got no error codes or anything, even when I push the heated wheel button, no errors, just nothing happens obviously...
Good luck.
      11-10-2018, 12:40 AM   #14
MichalM240i
Czech_Republic
145
Drives: M8
Hi Chris,
Thanks
Michal
Hi
Good luck.
Awesome, that sounds really easy! Thanks for your help :-)
      05-22-2021, 11:15 PM   #15
M FUELED
M FUELED's Avatar
Drives: 2017 BMW M2
Dude thank you sooooo much. I literally was here trying to remove the airbag for about 2:15 and well with the Allen key you saved my life lol I did it in about 3 minutes, thanks again.
      05-23-2021, 08:10 AM   #16
BeautyInMotionF22
Drives: E36,E92,F22
One piece of advice, wrap something like a rag in your trunk latch ao you dont accidentally close it with the power disconnected.
If you do this you will have to pop the hood and run some power to the cars jump terminals in the engine bay in order to get the trunk open again to get at the battery.
      08-06-2021, 02:06 AM   #17
JanGD
Drives: M235i F22 MY2014
Hi there, from what model was this steering wheel and is it also a bit smaller diameter than the original?
      08-08-2021, 09:37 AM   #18
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
it was the OEM BMW m performance wheel for the 2 series.
2014 M5
1999 E38 728i -sold
M235i - sold
