07-19-2015, 12:51 AM | #24 | |
Rep 1,627
M4 in MG | 6 MT
07-19-2015, 07:44 AM | #25 |
Rep 63
Just showing a fellow poster an option if they wanted to see some high altitude testing...I don't know of any other source and the magazines can't be believed.
I agree they do some weird things but for us at ASL it helps see what kind of real performance we'll achieve. Most reviewers drain the tank, change tire pressures, empty vehicles of spare tires, run on a special track and are at sea level to get their 0-60 times...not a true test. |
07-19-2015, 02:21 PM | #26 | |
Rep 4,341
As air gets thinner, there is less resistance on the turbo impeller so I can spin faster and force almost as much air into the engine. That is why turbochargers were originally vital for aircraft flying at altitude. A non X drive M235i at altitude will be faster as it is lighter than X version. The M235i is very heavy already, I really wouldn't add AWD unless I really had to! Just 2 cents. |
07-19-2015, 04:09 PM | #27 | |
Rep 7
07-19-2015, 04:25 PM | #28 | |
Rep 281
"NA cars will lose far more power at elevation then cars with tubro" A car without a turbo will lose MORE power at elevation then a car with a turbo. |
07-19-2015, 04:26 PM | #29 |
Rep 893
I think his logic being that the xdrive weighs more, it won't be as fast. I feel like the added traction of the xdrive would at least make up for the added weight.
07-19-2015, 05:47 PM | #30 | |
Rep 2,010
N
As to the aircraft turbos, they are large enough to allow the engine to develope sea level rated HP to very high altitudes; sometimes over 20,000 feet. Obviously, that much turbo capacity is not needed on car engines. I imagine they seldom go above 10 or 12 thousand feet. With our turbo cars, the necessary boost is controlled by the computer and a myriad of sensors, so it automatic. With most aircraft, the pilot must monitor a manifold pressure gauge and periodically increase the throttle as manifold pressure gradually decreases during climb. Gradually increasing throttle gradually closes the turbo waste gate. Once the waste gate is fully closed, the engine will then gradually lose HP as altitude continues to increase.
07-19-2015, 05:59 PM | #31 | |
Rep 4,341
Did YOU read my post? Is basically agrees with you?? ??? Last edited by nachob; 07-19-2015 at 06:07 PM.. |
07-19-2015, 06:06 PM | #32 | |
Rep 4,341
So you are sacrificing fuel mileage, feel, performance and adding purchase and maintenance costs for just a little extra launching traction. Unless you live in bad weather, I don't think it's worth the sacrifice. |
07-19-2015, 11:03 PM | #33 |
Rep 1,066
07-20-2015, 11:39 AM | #34 | |
Rep 4,341
07-21-2015, 12:48 AM | #35 |
Rep 3
