07-22-2014, 12:53 AM | #133 |
Rep 5,262
You are right... i probably copied down everything to 0F for the original values...
I remember mine were different too FF for everything should work.... |
07-22-2014, 01:01 AM | #135 |
Rep 623
If I chose wert_01 from the drop down, I think it did change to Werte=00 automatically, and wert_03 changed it to Werte=10 if I remember correctly. Like you said, I can try messing with them and see what happens though not really sure of the usefulness of this coding.
07-23-2014, 01:39 PM | #141 | |
Rep 347
iDrive > Settings > Doors/key > Acoustic signal lock/unlock and ...> Flash when lock/unlock.
F22 * (N55 + 6MT) ÷ PSS = FUN
07-23-2014, 01:43 PM | #142 |
Rep 623
Yeah, the flashing can be done through iDrive and it works of course.
I find the best (short of having an alarm and acoustic signal) is to have the auto fold mirrors on remote lock/unlock...great visual signal that the doors were locked. Oddly the mirrors sometimes also fold when you touch the handle to lock, but not always. Haven't figured out why it only happens sometimes, maybe it depends on the length of time the handle was touched to lock (short quick touch = no fold, long touch = fold?). |
07-23-2014, 01:48 PM | #143 |
Rep 5,262
Ya there is a delay...
Delay for mirror close Yes FEM_BODY 3053 KOMFORT_SCHLIESSEN werte = 0F (1500ms) werte = 03 (300ms) I set mine to 300 so if you just touch it, it will not fold but if i press just a little bit they will fold if you want always fold you can set it to 0 and will always fold |
07-23-2014, 04:09 PM | #145 | |
Rep 333
Unfortunately for me, I don't have either. |
07-23-2014, 04:19 PM | #147 |
Rep 333
A car equipped with GPS and complicated ignition system really doesn't need an alarm, but no acoustical sound unless you get the alarm is pretty stupid, along with quite a few other features that you can code in but BMW just wouldn't let you have it as stock. What the F is that for?
07-23-2014, 05:03 PM | #150 |
Rep 333
I changed both "remember last AC setting" and "always remember air circulating" to default, yet the climate control still turns off as soon I shut off the engine. The comfort/auxiliary vent option is also grayed out. very weird.
07-23-2014, 05:32 PM | #151 |
Rep 5,262
i think it always shuts off when you turn off the engine but turns on automatically when you start it again...
what are your default values for AC and recirc? mine are: MEMORY_UMLUFT AKTIV = 01 DEFAULT = NITCH_ACTIVE MEMORY_OFF NICHT_AKTIV = 00 DEFAULT = NITCH_ACTIVE Last edited by pikcachu; 07-23-2014 at 05:43 PM.. |
07-23-2014, 05:33 PM | #152 |
Rep 5,262
07-23-2014, 06:40 PM | #153 |
Rep 333
07-23-2014, 06:42 PM | #154 | |
Rep 333
