2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Dashcam cable woes
      09-30-2023, 11:19 AM   #1
nazali
nazali's Avatar
Drives: 230 2020 vert F23
Dashcam cable woes
I bought the official thinkware cable (hardwire one) and was going to install, but I suddenly thought I should test it. So I continuity tested from the cables to the plug
The ground wire shows continuity to the shank (1), the battery wire (red) showed continuity to (3) but the ACC wire showed no continuity to anything, I got a bleep every now and again on (2) regardless of how I moved the wire or plug.
NO shorts, so I connected it up to a battery charger, earth and first the red and then the yellow, dashcam wouldt start. (I put the old cigar lighter cable, started up)
I actually wanted the acc only function. I read somewhere that you may need to short the red and yello to start up a dashcam if your using the ACC only function.
But I didnt wanna, blow my working dashcam
I think the cable is faulty, but I never used it for like 6 months, so doubt thinkware will help
Just ease my mind, how I'm testing is right (I bypassed the fuses on the wire and went stright on the cable
