Sony xm-gs6dsp amp installed and need some help on fine tuning it. |
02-16-2022, 07:25 PM | #1 |
Rep 199
My car came with the hi-fi system and I have installed this amp and will be installing HK deck speakers, HK door speakers, and HK front tweeters (HK subs are already installed.) the bass already sounds better, but the speakers don't quite sound right. The images below show how I have everything wired up. Not quite sure what's the best way to make adjustments to this amp, on the amp itself, using the app, or both? Do I have everything connected correctly?
Here is a link to the manual pages 10-15 show the different ways to wire it up: https://www.sony.com/electronics/sup.../47333641M.pdf
2017 M240i - Estoril Blue
02-16-2022, 09:35 PM | #2 |
Rep 213
I'm assuming you bought a wiring harness to bypass the factory amp? If so then you should not be using the high input section of the Sony amp. Use the low input section. High input section of the Sony amp is assuming you'll be using the speaker outputs from the factory amp which you aren't because you are bypassing it with the Technic (or ebay)harness. Look at page 11 of the Sony instruction manual, not page 12 like you attached.
Regarding tuning, that's a whole other discussion that you'll need to do your own homework on. There is a TON to learn. I'm still a student of this myself as this stuff takes years to grasp if you only give it limited time like me. But if your up to it, the payoff is not paying a shop tune your system. Start here: https://www.audiofrog.com/audiofrog-tech-blog/ EDIT: I noticed that you edited your post to display page 11 now and not page 12 like you did earlier so not sure how you wired your amp up at this point...? Last edited by jv92red; 02-16-2022 at 10:07 PM.. |
02-16-2022, 10:41 PM | #3 |
Rep 199
Thanks so much for the info. Yes I got an adapter harness that you suggested.
The reason I edited the post is I read the manual more closely and found that I couldn't get any audio from the line input connector. Turns out I had to run a wire from the remote wire to one of the high pass pins. Tomorrow I'll work on tweaking the audio.
02-17-2022, 08:54 AM | #4 |
Rep 1,264
The HK speakers aren't very good. I replaced the HK speakers in the doors and in the rear package shelf. The sound is much better. Also, I replaced the amp with an Audiotech-Fischer MATCH BMW 7UP amp with a USB module. Why? The factory head unit has a crappy digital to analog converter (DAC). The amp's USB input relies upon the amp's DAC. That way I can send digital FLAC (lossless) files to amp's DAC. The sound is much better-clearer, detailed.
02-17-2022, 01:45 PM | #5 | |
Rep 199
10-09-2022, 11:37 PM | #7 | |
Rep 213
02-23-2023, 01:20 AM | #8 |
Rep 92
By the way, people say hi-fi door speakers are coaxial, but I just removed mine to replace it with an Aliexpress B&W knock-off b/c I need the secondary port for HK sail panel tweeters that I bought from a member here, anyhow, my door speakers are standard single cone driver, not coaxial. What was in yours? my car is 2014.
09-27-2023, 03:54 PM | #9 |
Rep 27
Sorry to revive a dead thread - but does this mean that the XM-GS6DSP support balanced/differential inputs? If it would work with the technic harness I'm guessing it would work with E90s as well (Hifi 676)?
