2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Fuse Box Location
      07-16-2021, 11:16 AM   #1
nazali
nazali's Avatar
Drives: 230 2020 vert F23
Fuse Box Location
Can anyone tell me where the fusebox is located for in my 20 f23 cab
on the 1 series it used to be in the glovebox
somone said there are 2 one in the trunk the other in the engine bay
I'm having a dash cam installed, and wanna make sure they dont chop any wires or "tap in"
      07-16-2021, 11:24 AM   #2
nazali
nazali's Avatar
looks like manual says engine bay and trunk,
unless anything different I think I'm good
      07-16-2021, 11:44 AM   #3
VAcurler
Drives: 21 F23 M240i MT + 09 e90 328i
The one in the trunk is the main one. In the engine bay there should be some under the plastic battery cover. I was not able to find a listing of which was where, but if you are doing a new fuse specifically for your install (using an empty/not used fuse) versus using a fuse tap your best bet is in the trunk.
nazali1313.50
      07-16-2021, 01:48 PM   #4
nazali
nazali's Avatar
thanks,
no what I meant was I don't want them to "cut into an existing wire" but take a fuse tap (adapter) like the did previously. Last time the fuse box was in the glove box so really easy.
txs!
      07-16-2021, 01:49 PM   #5
MidwayMuller
MidwayMuller's Avatar
36
Drives: BMW M235i
There are 2 main fuse boxes as you said (hood and trunk), and something like 4 other modules with fuse panels.
If you're doing a dashcam hardwire, you might get battery drain messages unless you wire into the FEM directly.
It's located under the front passenger kick panel/carpet, I followed the process from BMW's own Advanced Car Eye dashcam instructions:
Red (power) to #20
Yellow (accessory) to #33
Black (ground) to #24
nazali1313.50
ubul0.00
      07-16-2021, 03:38 PM   #6
nazali
nazali's Avatar
Hmm not sure, I'm happy with them tapping into that, although point taken about battery drain messages. On mine, I have a software option for 2 things, sentry mode (i.e. when not driving) and a voltage sensor to switch off if the battery goes below a certain point
on mine I didn't have sentry mode and just used it for driving.
I can keep an eye on battery drain from ista/inpa and monitor it if I have any issues
txs for the insight
      10-28-2023, 10:05 PM   #7
ubul
Ubul
Drives: Mini R57 LCI, BMW F23 LCI
Red (power) to #20
Thanks for this idea. So I checked out the original installation instructions... it is fairly ghetto from BMW, which them splicing into the cable harness with those connectors instead of just providing a plug on that stupid control module for the dashcam.
Anyway I think you may have mixed up pin 20 and pin 33. Pin 33 is the supply
