2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics No Audio From Car
      04-18-2019, 02:34 PM   #1
yugiooh
Drives: 2016 M235XI - F23
No Audio From Car
I Drive a 2016 m235xi Convertible.
I haven't done anything to the car but one day the audio stopped working.
No sound from radios, sensors or anything.
Before I bring it to the dealership wondering if you guys have any ideas?
I've only tried to update the system so far. Did Not work.
      04-18-2019, 03:42 PM   #2
bmtespar
bmtespar's Avatar
Drives: 19 X3 30i, 18 230iX Vert
Remove the positive terminal from your battery for 5 minutes and reconnect. See if that solves the issue.
Current: 20 M340i
Sold: 19 x3 30i X drive, 18 230i X drive Convertible
18 x3, 30i X drive 16 428i Convertible, 16 X1 X drive, 14 i3 Rex, 14 328i, 14 x1 28i X drive, 08 328i, 03 M5, 99 323i Convertible, 00 z3 M Roadster, 99 328i, 00 323i
      04-19-2019, 01:22 PM   #3
aerobod
aerobod's Avatar
3626
If the headunit still has power, try holding the power button down for 20 seconds or so, which should initiate a reboot.
      04-19-2019, 01:24 PM   #4
yugiooh
I'll try it tomorrow
Power button? U mean the on/off for the radio?
      04-19-2019, 02:31 PM   #5
JohnnyCanuck
Drives: 2018 Audi RS3
Yes ... the volume knob is also the power button. By pushing and holding it for 20 seconds, you cause a system reboot.
      04-20-2019, 07:26 AM   #6
yugiooh
I tried the system reboot didn't work. Will try unhooking the positive battery terminal later.
      04-20-2019, 08:13 AM   #7
EEBreh
Drives: "M" 235i
Do you have an HK amp? Ive read those can go bad. Check fuses too.
Disconnect the negative first. If you disconnect the positive first and you accidentally hit the chassis with a wrench you can create a mess pretty quickly.
      05-17-2019, 11:05 AM   #8
yugiooh
Update
The radio started working again by itself a couple of days later for a week. Then all of a sudden it stopped.
Yesterday I started hearing snap crackle and pop sounds coming from my speakers does this mean my amps dead?
Still haven't unhooked my battery yet.
      05-19-2019, 10:27 AM   #9
MarcoZandrini
Drives: 2018 M240i
Try disconnecting the negative battery cable to see what happens.
      09-23-2023, 04:45 PM   #10
xjakex956
Drives: 228i 2016
did you ever figure out the problem with the audio im getting the same issue
