2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning M240i Catback or Axelback
      03-01-2017, 09:34 AM   #89
GDLF.
Germany
14
Drives: 2019 G01 X3 M40i
Originally Posted by Joe240 View Post
Exhaust came in a little bit ago. Unfortunately I'm at work so pictures will be put up tonight. Wife facetimed me so we can make sure everything was there. The one box was open when it was delivered and it also had a foot print on it (gotta love delivery companies). Everything appears to be there and in great condition. Again, pictures will be up tomorrow. Might wash the car tomorrow morning as well so I can do a before and after video.
Congrats!
Glad that there is no damage and everything is in its place! Can't wait to hear it
Thanks for keeping us updated!
Joe2402925.00
      03-01-2017, 09:35 AM   #90
AlexM240i
Drives: M240i
Wife should take the pictures and send them to you !!
Joe2402925.00
      03-01-2017, 10:18 AM   #91
Joe240
Joe240's Avatar
Drives: 2021 C8 Corvette 1LT
She does take better pictures than me
AlexM240i101.50
      03-01-2017, 03:53 PM   #92
Superman_M240
Drives: 17 F22 M240i
Congrats! I'm curious to see how it sounds. I've heard great things about Akrapovic as well. They were just a little pricey for my taste. Be sure to post a before and after clip of the exhaust!
For sure I will try to do a before and after
Hopefully I get to see it by the end of March or the beginning of April
AlexM240i101.50
Joe2402925.00
      03-01-2017, 05:58 PM   #93
AlexM240i
Drives: M240i
The Akrapovic system comes with ECU controlled valve ? The midpipe is resonated or non resonated ??
      03-02-2017, 10:52 AM   #94
Superman_M240
Yea it comes with ecu controlled valve and since the midpipe is two central link pipes replacing the single stock pipe, I don't think it is resonated.
AlexM240i101.50
      03-02-2017, 11:04 AM   #95
Joe240
Joe240's Avatar
I haven't forgotten about you all I promise. I took pictures last night when I did the unboxing. I also took pictures of the install that I'm going to post up. I also took a quick (kind of crappy I feel) before video with a cold start on the factory setup. I will do a cold start with the Remus setup tomorrow morning so it's similar starting temps.
Got the install done today, there are some things to note during the install that turned what should of been an hour install using a lift, into a 3 hour install (key points will be in the write up). Hopefully it will help others make an easier install if they go with the Remus exhaust.
First impression: resonated midpipe makes the exhaust about as quiet as stock when under normal load which is great so I don't piss off my German Community here. When doing spirited driving in comfort mode, you can definitely hear the exhaust and it sounds awesome. It has a lower exhaust note which makes it sound great. It doesn't have a tingy or raspy sound to it, nor does it sound like a ricer. Definitely hear the burbles (overrun) when in sport mode more now. WOT in the higher RPMs kind of sounds like stock to me (inside, windows up, sunroof closed) and that's probably due to the ASD (which I plan on disconnecting the middle speaker one day to deactivate it). My wife says though that at WOT it sounds a lot better than stock and sounds amazing.
Overall, worth the $2k for the exhaust. The difference IMO is night and day. Last exhaust system I did was a flowmaster on my old Dakota and although the install was simpler on the flowmaster, the quality of the exhaust, materials, and thought that went into the design is very apparent on the Remus system.
WITH ALL THAT BEING SAID! Can anyone direct me on how I could insert pictures in between my text when I type up the walk through so I don't have to say "Refer to picture #1, 2, 3, etc." ? I will also include the videos in the walk through but probably at the end.
AlexM240i101.50
SCCThree816.00
      03-02-2017, 11:07 AM   #96
Joe240
Joe240's Avatar
The Remus midpipe is actually 2 separate pieces so maybe Akrapovic did the same thing. Did they give you an option to select resonated and non resonated?
The Remus one has a dual pip up front off the DP back to about the rear diff. Then it comes back together for the second pipe which has a small resonator on it.
AlexM240i101.50
      03-02-2017, 11:08 AM   #97
Joe240
Joe240's Avatar
The Remus one has a dual pipe up front off the DP back to about the rear diff. Then it comes back together for the second pipe which has a small resonator on it.
AlexM240i101.50
      03-02-2017, 12:08 PM   #98
AlexM240i
Drives: M240i
Another day without pictures and videos ??
      03-02-2017, 12:38 PM   #99
Joe240
Joe240's Avatar
Just 1 more day Then I promise it all will be put up. I want to make sure it's complete for you guys. At least I gave my opinion about the exhaust and a little description
AlexM240i101.50
SCCThree816.00
      03-03-2017, 06:49 PM   #100
Joe240
Joe240's Avatar
Here you go Gentlemen. Pictures of the exhaust from unboxing. Here's the links for the before and after videos as well.
AlexM240i101.50
GDLF.14.00
      03-06-2017, 06:04 AM   #101
AlexM240i
Drives: M240i
Some thoughts about the Remus system:
1. The system is beatiful. Top notch quality.
2. I was thinking the resonator would be smaller and embeded in the tube itself. Looks big.
3. Any drone or annoying sound so far? Do you think i'ts too quiet ? With a stock dp as a i have, would you go resonated or non-resonated ??
4. I've watched your driving video a few times but i couldn't figured out if the exhaust pops and gargle (the main problem with the stock system). Maybe the Gopro couldn't record that type of sound ??? It would be great if you can make a video with your iPhone with the engine hot y and rev it in the different driving modes.
Thanks again.
Joe2402925.00
      03-06-2017, 11:28 AM   #102
Joe240
Joe240's Avatar
3. Any drone or annoying sound so far? Do you think i'ts too quiet ? With a stock dp as a i have, would you resonated or non-resonated ??
Thanks again.
I was surprised with the size of the resonator as well, but it really is in the only place where there is a straight enough pipe for a resonator that isn't part of the dual section.
No drone at all, nor any annoying sounds. I'm really happy with the exhaust. I will say that it is a little on the quiet side so I find myself putting it into Sport mode more often. I have a catless DP to put on though which I knew would make it louder anyways. That was the reasoning why I went with the resonated midpipe.
If you're sticking with the stock DP, then go non resonated. If you plan on going catless DP, then resonate the midpipe. This way you wont be too loud and you shouldn't get any drone.
As far as the pops and gurgles, that's the overrun that I (think) mentioned. In Sport mode it does it all the time with light or hard throttle. In comfort mode, you don't hear it (maybe rarely, but I haven't been paying attention in comfort mode). I know that they all will be more apparent in all driving modes once the catless DP goes on.
I did notice that in park when revving, it doesn't do the overrun it seems. I'll mess around with it to see if I can get some better audio on my iPhone or camcorder.
I do ear the overrun when playing it through my TV to my soundbar with wireless sub. Were you using headphones or computer speakers when you listened to it? It might be just the frequency of your speakers. I know that sometimes it was hard to hear on the video because of the wind as well though.
AlexM240i101.50
      03-20-2017, 12:40 AM   #103
mpbruin108
Mpbruin108
mpbruin108's Avatar
187
Drives: I'm a hypermiler
Maybe it's must me but from the sound from the videos, it doesn't sound too much different. Just slightly. I was hoping for a more noticeable sound difference. I got the MPE and that doesn't sound too much different than the Remus. Maybe I'm tone deaf. Oh well.
So Cal Drivers: Get your Tires from us to get them QUICKLY (same or next day) and at a GREAT Deal.
2244 Tyler Avenue, South El Monte| Call: 626-443-8539
Active: 2015 BMW i8, 2024 BMW iX, 2018 Mclaren 720s
      03-20-2017, 01:58 AM   #104
Joe240
Joe240's Avatar
It does have a different tone. But because of the resonated midpipe and factory downpipe, it starts off loud when you first start, but then gets extremely quiet. My friend heard it and was surprised. Said you couldn't hear the exhaust, just the engine.
This isn't my final setup though. I'll be putting the catless DP on in a couple weeks. That'll make even idle louder. Currently though, it's louder and a different tone when driving. It's just idle that's quiet. If you don't plan on replacing the stock DP to sport or even catless, then I'd suggest the non resonated midpipe.
Another thing to remember is that camera microphones don't capture low sounds very well. So always take videos with a grain of salt, but something is better than nothing.
      03-20-2017, 08:20 AM   #105
AlexM240i
Drives: M240i
Did you remove the midpipe resonators after the MPE ??
      03-20-2017, 10:14 AM   #106
mpbruin108
Mpbruin108
mpbruin108's Avatar
187
Not yet. I wanted to do my Dinan tune and a dyno run first. Also, looking to see if there is a better sound combination out there before cutting my stock pipes further. This is a lease you know. haha
AlexM240i101.50
SCCThree816.00
      03-20-2017, 10:51 AM   #107
Joe240
Joe240's Avatar
Removing the midpipe resonators would be the next step to making the car louder. You could probably have a custom midpipe made and just hang on to the factory midpipe. I'm pretty sure they do not weld the MPE to the midpipe so should be an easy swap should you want to go back.
      04-14-2017, 04:29 PM   #108
228
228's Avatar
No_Country
22
Drives: Bmw m340i
when will awe come out with their exhaust for the 240i?
      04-15-2017, 12:50 AM   #109
Joe240
Joe240's Avatar
No idea. They still don't even list the 240 on their website.
      04-25-2017, 10:09 AM   #110
bowhun2r
bowhun2r's Avatar
Drives: F22/B58 M240xi
Originally Posted by AlexBeuro View Post
I'm kinda of leaning towards the Remus Catback but want to get a bit more info on the akrapovic exhaust. I really don't mind loud and my neighbors are spawns from hell so I think it would be a great motivator to get the loudest one.
This made my morning... "spawns from hell..." How I can relate...
