05-15-2017, 07:46 PM | #89 |
Reverse Homer
151
Rep 1,064
Ok I just installed today. Went for a initial spin and so far I can say I feel the power but suspicious about power delivery throughout the band.
First, installation was pretty easy. I am a novice hardware guy - but was able to get it installed. I did chip a sensor stopper so be careful when taking them off. However (thankfully) the Dsport was able to snap into place securely. The engine bay looks little different from what Dinan has on their site, we have to remove the battery cover to be able to zip tie the Dsport Module. The app is really cool and handy but it is half baked. There are two apps- make sure to download the one called "D-Sport". You dont have to do anything to connect - super easy but worried about security - technically I think anyone close enough to my car can change settings. I am not sure how Dinan is preventing that. I am not sure what the two toggles mean. There is one at top, and one on the bottom. The top toggle removes the option to chose which mode you are in. The bottom toggle is a toggler. What I am missing is how do I know which app is active? I see the PSI but does it set right away? Over time? When I click the top toggle? I went back and forth on the fly a few times and couldnt tell if it instantaneous. Anyway - to performance.... My tires are chirping and the car flies! I only tried up to Sport mode for now. So first drive Pros: Car is faster and you feel the power Can change PSI with app (love this over the JB+) No CEL Codes or any errors Easy Install Cons: App UX leaves something more to be desired. ***Power delivery isn't smooth on Sport mode. This could be that I need to break in the mode. At about 3k RPM keeping accelerator constant - you get a jump an I feel a lot of boost come in at once. I would have liked to see more smooth power delivery. Can anyone confirm a break in time in miles for when changing modes? Maybe let the ECU adapt to the new boost? My mods in addition to the DinanTronics Sport: BMS Intake Dinan Mid Pipe |
AlexM240i101.50 |
05-16-2017, 12:21 PM | #90 |
Rep 410
Hi,
Please keep us updated on teh power delivery issue. I want ot smooth and now are thinking of reselling the sport unit I just got (as unopened it better than used). |
05-16-2017, 01:50 PM | #91 | |
Rep 13
I'm at 2600 miles now so the training wheels are off. Not sure about the Sport, but the Elite turns the car into a little rocket.
2017 M240i xDrive Coupe | Dinan Stage 1 | Dinan Mid-Pipe | 'Dr. Strangelove' Sound Upgrade | BMS Exhaust Tips | K&N Air Filter | CF Mirror Caps
Vyruz Reaper151.00 |
05-17-2017, 01:47 AM | #92 | |||||
Reverse Homer
151
Rep 1,064
Well the good news is it has gotten better driving another 100 or so miles on it (and not changing maps). The bad news - it's still happening and I can't replicate. Here are thoughts: - WOT I have no issues. The car is so quick that I can't notice it if it's happening : - There are two types of non-linear acceleration I experience. 1. Spirited driving but not WOT - I experience boost come on at 2.5-3k. and the one that bother me most is 2. 10-20% throttle between 2-4k rpm I get "jittery" acceleration. I feel boost come on then off then on then off and the car is "jumping". The problem is I can't replicate it. But it is happening less often now. Mainly in 2nd and 3rd gear. - I totally believe that the ECU needs 50 miles after you set it to a mode to adapt to the new conditions. - this may be in my head, but I was on shell 91 gas experiencing the issues. I just refilled my tank with Chevron 91 and haven't experienced jittery acceleration yet. This may be due to the miles driven to let the ECU adapt or it may be the gas type - just another data point. - After experiencing the power delivery concern s, got me thinking- has anyone created an ECU flash for the 240? That would be the best way to get smooth delivery and proper tuning for our cars. - +2 psi is smoother than +3psi. I haven't tried Race mode yet. - Tune does add that extra power and a big plus on the price point. I wouldn't buy the Dinan Elite as after my mid pipe and intake, I'm not going to be doing any other performance mods. Maybe exhaust/muffler down the road but that would be it. Same goes for JB4. I might be inclined to try out the JB+ but I suspect it's going to be the same or worse than the Dinan tune as the Dinan taps into two sensors. That said, it would be a lot easier installing and uninstalling the JB+. No zip ties, and just one sensor on the front of the engine bay. I'm going to look into who does flashing. Would be nice if I could flash myself via OBD2. I would pay 1k for that. |
05-17-2017, 02:51 AM | #93 | |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
05-17-2017, 02:54 AM | #94 | ||
Reverse Homer
151
Rep 1,064
That's encouraging to hear about the JB4 map1. I might go that route. |
05-17-2017, 05:01 PM | #95 |
Reverse Homer
151
Rep 1,064
Day 3 update:
The tune definitely needs about 30-50 miles between changing modes for the ECU to adapt. The power deliver has gotten smoother and the jittery acceleration is gone. I still do experience the 2.5-3k boost come on in a non linear fashion but even that has become smoother leaving it on one setting. I've been testing and enjoying +2 psi mode ( forgot what it's called) I'll try +3 psi next and see if I get some non linear acceleration experiences and how long it takes for the car to adapt. Also a weird side effect after installing the tune is that my Dinan mid pipe mod is more quite than it was without the tune. I lost some of the pops and burbles. Could be normal and after breaking in the mid pipe or could be the tune. Either way.... Bummer. |
05-19-2017, 12:06 AM | #96 |
Reverse Homer
151
Rep 1,064
Day4 update.
Switched to sport+ (+3psi) and wholly jittery jumpy acceleration. I drove around in circles for about 10 miles and acceleration started becoming smoother but not quite there. I'll drive more tomorrow and report back to see how many miles it takes for the ECU to adapt Sport+ feels significantly faster than the sport though it's only 1 psi more. Anyone else running the dinantronics? I feel like I'm having a conversation with myself here |
05-19-2017, 01:34 AM | #97 | ||
Rep 178
05-19-2017, 06:46 AM | #98 | |
Rep 558
05-19-2017, 02:42 PM | #99 | ||
Reverse Homer
151
Rep 1,064
Sport+ vs Sport. The Sport+ feels significantly faster but also you feel that non liner acceleration more so than Sport. Both a great. I might hone in on Sport for daily driving and Sport+ on occasion. I wish there wasn't a 30 mile drive buffer for the ECU to adapt but such is with piggyback tunes. I'm gonna check out valet mode for the hell of it. Then I'll try Race. Lastly- seems like the higher the boost I go, the more it negatively impacts my Dinan mid pipe sound. Weird. Huh? |
05-19-2017, 04:37 PM | #100 | |
Rep 558
And, yes boost level negatively affecting exhaust sound is very weird.
05-19-2017, 06:21 PM | #101 |
Reverse Homer
151
Rep 1,064
05-19-2017, 06:35 PM | #102 |
Rep 178
How did you get this pin out?
05-19-2017, 07:11 PM | #103 |
Reverse Homer
151
Rep 1,064
Its the one on the bottom of your pick. Pull the white tab out one click. Then you gotta pull/wiggle it off. It's a little tough but it will pull off if you keep pulling
That picture is rotated, right, meaning it's not how you see it while looking at the engine |
kohlzor46.50 |
05-20-2017, 03:17 AM | #104 |
Rep 1,303
Yea looks like the front connector before the throttle body. I use a small flat head to push the white clip down a little and the push it out 1 click. Fat fingers make it hard to mess with small clips >.<
kohlzor46.50 |
05-20-2017, 11:50 PM | #105 | |
Rep 178
I did have to remove the batter cover and mount the dinan there. I had a bit of trouble getting the engine cover back on, was I suppose to hide the connectors underneath existing wires or something? Or should they just be sitting there. |
05-21-2017, 08:23 AM | #106 | |
Rep 558
05-23-2017, 05:29 PM | #107 | |
Rep 178
Also have you tried race mode? I have been driving around in Sport+ and don't really notice a difference TBH. |
05-23-2017, 06:17 PM | #108 | ||
Reverse Homer
151
Rep 1,064
Mid pipe I also noticed a difference in sound. Both modes sounded awesome with comfort having little no pops and burbles and sport having a ton. I liked the difference between the two. Dinan Sport plus midpipe, both are quieter and less pops and burbles in sport mode sometimes none. I'm assuming it's because based on my throttle, I used to push it more to move and heard it more often but with Dinan tune throttle response is better making less accelerater despress and less sound. I dunno. Sport+ in Dinan tune I noticed a difference. Give it 20 miles for the ECU to adapt. Sport on Dinan tune it was hard to feel the difference but the throttle response was better so felt faster. Haven't tried Race, im on a business trip atm. Valet mode I noticed huge drop in boot through the mid and high parts of the power band. Boost still came on around 2.5-3k but it didn't build and was flat thru 6k rpm. I guess that worked : |
05-23-2017, 06:40 PM | #109 | |
Rep 178
Waiting for you to try race mode before I give it a go Also what is the max PSI you saw when WOT on Sport +? |
05-23-2017, 09:52 PM | #110 | ||
Reverse Homer
151
Rep 1,064
I won't be back in socal until June 18th |
