09-19-2016, 11:16 AM | #89 |
Rep 260
09-19-2016, 01:57 PM | #90 |
Rep 129
Drives: 2016 MW M235xi
I was just about to respond saying I know about the Michelin man, he was just no where to be found.
09-19-2016, 08:19 PM | #91 |
Rep 300
I've been reading this thread with some interest. My 228i THP has just 6300 road miles, maybe a little enthusiastic at times, but nothing really hard, and certainly no track time. The outsides of my front PSSs are scrubbed to hell already, and no little Michelin Man visible (I can see it on the much-less-worn rears).
FRONT REAR I ran the fronts at around 33psi (32 indicated on the iDrive) until recently when I upped them to 37 (35.5 indicated) which certainly improved both the road noise and the steering feel, but there's no accounting for lack of camber... |
09-20-2016, 10:24 AM | #92 | |
Rep 556
09-20-2016, 10:55 AM | #94 | |
Rep 556
09-20-2016, 11:00 AM | #95 |
Rep 1,541
I've done that to one of my cars. It was 20 years ago...don't judge me
09-20-2016, 11:00 AM | #96 | |
Rep 1,084
I'll give it a go this weekend
09-20-2016, 11:03 AM | #97 |
Rep 556
09-20-2016, 11:59 AM | #99 | |
Rep 1,541
Hope the wheels worked out for you
09-20-2016, 12:08 PM | #100 |
Rep 300
09-23-2016, 11:53 AM | #101 | |
Rep 5,372
Since Vorshlag won't revise the perch, perhaps go to a machine shop and have them modify the perch as necessary. |
09-23-2016, 08:02 PM | #102 | |
Rep 556
Anthony235715.00 |
10-03-2016, 09:22 PM | #103 | |
Rep 86
Bob |
10-03-2016, 10:10 PM | #104 |
Rep 1,084
Vorshlag has notified me they're re-designing the perch to better accommodate the stock isolator and spring. They'll be sending me a new set of plates to evaluate.
Kudos to Vorshlag for going the extra mile here: apparently, they went back and put their initial testers under an interrogation lamp , wherein the testers confessed to hearing the same things as I did.
10-03-2016, 10:21 PM | #105 | |
Rep 86
10-10-2016, 01:40 PM | #106 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Just remember camber plates is a race car part you are using on the street so a noise here and there should be expected. If there is a flaw in the design, that obviously should be fixed.
10-11-2016, 05:03 PM | #107 | |
Rep 1,084
The vendors for every plate I've tried have all claimed that their products make no noise (implying street-ability), but none have really delivered on this promise, instead retreating to "well, it is a race part..." I realize now that you can't expect a spherical bearing to be noise free in this application, no matter how tight or how big. This platform really needs a solution for the street, though. Everyone I talk to about their F-series car, whether they track it or not, complains about outer front tire wear. I suspect that a fully streetable camber plate (e.g. fixed at -1.0deg or -1.5deg with a urethane or rubber top bushing) would sell like hotcakes.
10-11-2016, 05:16 PM | #108 | |
Rep 596
I must say mine don't make anywhere near the noise yours do in that video. Worst i get is a very slight rattle at low speed (stock perch and springs with dust boot in place). Have they improved at all over time? |
rwalker329.50 |
10-11-2016, 05:53 PM | #109 | |
Rep 1,084
the slight rattle at low speed is what I'm griping about: you'll find that you'll be able to hear it at nearly any speed over rough surfaces, and that it will become worse over time, ultimately requiring replacement
10-11-2016, 06:29 PM | #110 | |
Rep 596
The only concern i have regarding the design is the less than optimal perch configuration with the isolator in place. Which could prove costly to amend even just replacing that part (when they update it) on this side of the pond. If i don't encounter any major issues with it, ill probably leave it be. Luckily most of the roads i use are in pretty good condition, bar the odd pothole here and there. Its mainly going over speed humps where the rattle really reveals itself, but I'm finding it entirely liveable atm. Tyre roar and wind noise go some way to cancel it out at highway speeds, and its more or less imperceptible with music playing. Saying that, i wouldn't want it to get much worse than what it currently is being a dd. So as long as these prove to be durable and long life, ill be a happy camper. |
