08-16-2016, 09:46 PM | #23 | |
Rep 957
You could prob. Trim the dust boots. My guess is they would tear if you leave them. Nvh is going to be from the bearings transferring more force/vibration, feel to the strut towers, oem have more compliance which absorbs some of the nvh as well as feel. I doubt these are terribly loud they look well designed to properly distribute the load. If your driving entirely street, why add camber plates? Like adding a wing to a fwd car. |
08-17-2016, 03:32 PM | #24 | |
Rep 2,942
... or you're driving this:
Anthony235715.00 |
08-17-2016, 03:47 PM | #25 | |
Rep 1,084
I haven't done the friction tape mod yet, and I'm running without the stock isolators. My plan is to drive 'em as-is until first week of September. This will include a couple of weeks of daily driving, a road trip from San Diego to Monterey, an autocross, and 2 days of HPDE at Laguna Seca. I think this car needs more camber for street driving. My stock MPSSes had very heavily worn shoulders with just 1k of street drving.
Liquidpaper451.00 |
08-17-2016, 05:04 PM | #26 | |
Rep 845
08-17-2016, 05:08 PM | #27 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
-1 to -1.5 can do wonders on a street car. M cars run -1 from the factory.
Anthony235715.00 |
08-17-2016, 05:46 PM | #28 | |
Rep 1,084
I wonder how hard/expensive it'd be to make fixed camber plates that:
Such a thing might be made very cheaply, and thus could be offered in multiple variants, e.g. -1, -1.5 and -2 degrees additional camber. I've done some casual investigation on this front, but I'm not in industry nor am I a mechanical engineer, so the going is slow :-(
08-17-2016, 06:05 PM | #29 | |
Rep 845
I seem to recall Dinan made such a plate last generation with a fixed amount of added camber. Seems like a good idea to me for those who want a little better front end performance, but don't plan on going to the track really and/or are not willing to give up NVH for complete adjustability.
08-17-2016, 06:09 PM | #30 | |
Rep 845
My guess is that the BMW legal department is skiddish towards producing cars (other than full M Cars which are marketed as being "sporty") that have so much front end bite the back end gets loose. Imagine some family in an X3 getting the tail out in corners coming back from the grocery -- which would be sort of awesome.
08-17-2016, 07:43 PM | #31 | |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
08-17-2016, 09:16 PM | #32 |
Rep 957
You could just buy the lca and ts, I think that is almost an additional 1/2 degree. If you get real ambitious you could throw the camber correction kit wheel hub assembly's from bmw.
08-17-2016, 09:19 PM | #33 |
Rep 957
08-17-2016, 10:39 PM | #34 |
Rep 845
To talk about your mid-life crisis?
08-18-2016, 11:15 AM | #35 | |
Rep 85
08-18-2016, 03:07 PM | #36 |
3847
Rep 54,376
Drives: F80 M3
08-18-2016, 07:36 PM | #37 |
Rep 1,084
Knuckles = pricey! Also, we may already be running those...
08-18-2016, 07:37 PM | #38 | |
Rep 1,084
08-18-2016, 10:15 PM | #39 | |
558
Rep 1,477
Drives: 335i
I have f8x LCAs and have been looking for any ideas on how to re-center my front wheels, as I'm trying to maximize how much tire I can fit up front, and now that they're pushed forward I've lost about 7mm of fender clearance.
08-18-2016, 11:13 PM | #40 | |
Rep 957
08-18-2016, 11:14 PM | #41 |
Rep 957
08-18-2016, 11:15 PM | #42 | ||
Rep 1,084
It's possible that TSes don't help much with caster, but I find that hard to believe given how much the wheel moves back when you add TSes. The community suffered a bit of a setback when some aftermarket vendors initially evaluated the TSes and said "ah, they don't fit and they're the same length as stock anyway". Pparana is our TS Prometheus. Quote:
The before/after of wheel placement with TSes is definitely non-null. TSes will get you there. Check my posts on TSes. You can see that the F8x TSes are obviously longer, even on the bench. There is a small caveat to running TSes: less steering lock with aggressive front fitments. With 255/35r18s on 18x8.5et42, my front tires hit the TS just before full lock...
08-18-2016, 11:19 PM | #43 |
Rep 1,084
I trust you'll keep us updated and take lots of pics.
08-18-2016, 11:41 PM | #44 |
Rep 957
I am not a pic man, but Mostly just sorting a sub frame issue in the front. Adding some bracing from the m235i convertible, and looking for some better motor mounts.
Rear subframe is out as well, dumping all the stock bushings for that and the diff, upgrading to poly. Going to mod the cdv valve as well. Bumpers and lower skirts are out for paint, throwing on some carbon aero stuff and having the brakes podwer coated. |
