04-25-2016, 12:14 PM | #89 | |
Rep 1,084
http://www.realoem.com/bmw/enUS/part...&q=31122284531 http://www.realoem.com/bmw/enUS/part...&q=31122284529
04-25-2016, 02:26 PM | #90 | |
Rep 5,262
would be nice to compare part numbers There you go http://www.realoem.com/bmw/enUS/part...&q=31122284530 Same for the tension strut http://www.realoem.com/bmw/enUS/part...&q=31122284532 Last edited by pikcachu; 04-25-2016 at 02:34 PM.. |
04-26-2016, 01:21 PM | #91 |
Rep 6
Was wondering if any of the other Ops have tried creating more negative camber by upgrading the spindles on their M235. Seems BMW makes OEM spindle upgrades to correct for wheel alignment issues after an accident has "tweaked" the front end alignment ? Would this be a viable way to change camber without changing out the LCA and or TS. Thanks
04-26-2016, 05:48 PM | #92 | |
Rep 1,084
04-26-2016, 06:10 PM | #93 |
Rep 580
04-26-2016, 06:18 PM | #94 | |
Rep 1,084
IMHO, no reason not to use the M3/M4 LCA except for the clearance penalties and the slightly higher NVH.
04-28-2016, 01:28 AM | #96 |
Rep 4,516
If running coilovers, perhaps sniff out a set of these m4 GTS top mounts. From the CGI cartoon below, front strut top mounts look offset, perhaps an alternate OEM mod to m4 LCAs for built-in negative camber when upgrading to coilovers.
Depending price and availability etc, could be a viable noise-free alternative to aftermarket camber plates if these parts can be purchased from BMW at a reasonable price and then made to fit 3 or 5 bolt mounts on our cars...... BP |
05-08-2016, 01:28 PM | #97 |
Rep 1,084
I crawled under the car, but can't decipher the part numbers...
05-09-2016, 07:38 PM | #98 |
Car Enthusiast
282
Rep 501
Earlir in the thread I read someone saying that the LCA are not recommended on a X-Drive vehicle due to the stress it would put on the front driveline.
I dont think its going to put any extra stress on the driveline at all. My question is, will they fit on a Xdrive? is the Subframe mounting spots the same on the Xdrive as they are on the RWD? |
05-10-2016, 09:40 AM | #100 |
Rep 197
So the camber that is shredding the outside of my M235i's tired is due to the control arms? I was told it could be fixed by camber plates? Does anyone know the true answer?
16' M235i Active Autowerkes Stage 2 Tune/DP/FMIC/CP - Dinan CAI/Lowering Springs - 19x8.5/19x9.5 Forgestar CF5V Bronze Burst
05-10-2016, 09:52 AM | #101 | |
Rep 5,262
The only 2 ways to get more camber would be with the M4 LCA's or with camber plates.... M4 LCA's is the cheaper and cheaper to install option but this gives you fixed camber.... Camber plates are more expensive and can make noise but you have full adjustability |
05-10-2016, 09:54 AM | #102 | ||
Rep 197
05-10-2016, 10:09 AM | #103 |
Rep 197
How does the camber affect the appearance? Sorry a newb to the suspension world.
05-10-2016, 03:24 PM | #104 |
Rep 127
Increased negative camber pushes the bottom of the tire outward and the top inward. If you like a more "flush look" adding a modest spacer will move tire outward.
05-10-2016, 03:40 PM | #105 | |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Some camber plates are quieter than others though. |
05-10-2016, 04:58 PM | #106 |
Rep 5,262
05-10-2016, 05:14 PM | #107 |
3847
Rep 54,376
Drives: F80 M3
05-12-2016, 09:34 PM | #108 |
Rep 103
Anybody considering trying M2 front lower control arms? Going to see if my BMW buddy can check the part numbers tomorrow and see how much they are.
05-12-2016, 10:02 PM | #109 | |
Rep 1,084
http://www.realoem.com/bmw/enUS/part...&q=31122284529 ECS Tuning has great prices: https://www.ecstuning.com/b-genuine-...t/31122284529/
05-12-2016, 11:02 PM | #110 | |
Rep 103
