2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Lowering M235i with M-sport adaptive suspension
      02-01-2015, 04:20 AM   #1
moldcad
moldcad's Avatar
Poland
262
Has anyone lowered his M235i with active (adaptive) suspension, or is fitting aftermarket springs like H&R only recommended with the passive M-sport suspension?
previous: 2003 E46 330i SMG
just sold: 2013 F10 528i xDrive
my AWD beater: 2015 Golf R mk7 DSG
my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD
      02-01-2015, 08:45 AM   #2
philisme
Belgium
54
Drives: BMW 1M Coupe + M2 + 330e
2016 BMW 330e  [0.00]
2012 BMW 1M coupe  [10.00]
2017 BMW M2  [0.00]
Yep.
I've Eibach sprinds (pro kit) on my M235i with adaptive suspension.
It's more precise and still comfy. Good choice.
      02-01-2015, 03:27 PM   #3
hoppy6698
hoppy6698's Avatar
Drives: M235i, Estoril Blue on Black
Originally Posted by philisme View Post
Yep.
Which Eibach springs? Got a link, price, and approximate drop? Pics!
      02-02-2015, 11:50 AM   #4
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
I have H&R's on my adaptive M135i here in UK. Great mod, improves handling w/o ruining the ride. Stance is more level than slightly nose down stance of the eibachs.
Current '22 X3M LCI..
      02-02-2015, 01:56 PM   #5
AlexGT
AlexGT's Avatar
Guatemala
420
Drives: G05 X5 MSport
Originally Posted by hoppy6698 View Post
Pics!
hoppy6698 , I was quoted this part number E10-20-030-02-22 from Eibach, the drop is 20mm at the front and 10mm at the rear.
And, +1 on the PICS request please philisme
      06-01-2016, 03:37 PM   #6
philisme
Belgium
54
2017 BMW M2  [0.00]
My former M235i with Eibach Pro Kit (black springs) at Spa last year :
BMW 1M Coupe - AW - 2012
BMW M2 DCT - BSM - 2017
BMW 330e iPerformance - GSM - 2016
Dylan861330.00
      06-01-2016, 06:17 PM   #7
x233
Ukraine
284
Drives: M2C, M235xi
I run Eibach Pro-Kit springs on m235iX and Adaptive suspension. Really like them.
Part number for RWD is E10-20-030-02-22, or E10-20-030-03-22 for AWD.
Also, I use bumpstops that Dinan sells with their kit (oem part number 31331138814 front and 33536762722 rear) since the lowering seems very similar. Initially, I used trimmed original bumpstops and that sucked when hitting potholes, etc. The combo with "dinan" bumpstops works great, though.
The lowering is less than H&R which I think is good as you still get enough shock travel. for RWD it's supposed to be 20 mm front and 10 mm rear, for AWD it's 15 mm front and 10 mm rear.
I can confirm for the AWD as measured several months after install, exactly 15 and 10 mm on my car. The car actually looks lower than just 15/10 mm, but not slammed like on H&R. I checked and double-checked and it's only 15/10 mm lower although because the nose is a bit lower than the back it plays that visual trick on you.
The ride is a bit stiffer and somewhat harsher on road imperfections, think almost like sport mode on stock suspension, maybe a bit harsher on junctions but still absolutely usable for everyday and quite comfy overall.
Sharper turn-in, more precise and a bit better handling overall, a bit heavier steering that feels just right, less nose dive and better cornering, a bit less body roll, and what was most important to me - a lot more stable at high speed, a good satisfying planted feel.
hoppy6698127.00
      06-02-2016, 04:05 PM   #8
philisme
Belgium
54
2017 BMW M2  [0.00]
Same for me.
Eibach Pro Kit and really liked them
      06-13-2016, 11:25 AM   #9
Kenetic
Drives: 2016 MG M235i
Im running H&R springs on Adaptive. Definitely makes the ride a bit stiffer over bumps but normal driving is still very smooth.
2016 MG M235i | Black Kidney Grills | MPE l H&R Springs | IND Double Slat Front Grills | M Performance Front Lip | 19" VMR v710 w/ Hankook Ventus v12
      07-09-2016, 07:05 AM   #10
hoppy6698
hoppy6698's Avatar
Just a warning from my experience - HR sport springs destroyed the M235 struts on my car in all four corners. Never tracked while on, but all struts began leaking after the install by a professional shop. After contacting HR, they essentially said they just make the springs, they do not guarantee they will not damage OEM equipment, the risk is all on the buyer. So buyer beware.
For my part, I will have to revert back to the stock M235 suspension until a better solution comes along. For the moment, any coilover or other strut/spring setup lowers the car too far beyond the roads in my area to be comfortable with.
      07-10-2016, 07:28 PM   #11
x233
Ukraine
284
Drives: M2C, M235xi
It seems H&R 25 mm lowering springs may be a bit of an overkill for the stock adaptive shocks. There might be better options out there, in terms of function and shock's longevity.
To name a few:
1. Dinan springs plus bumpstops that come with them.
2. Eibach Pro-Kit (15/20 mm front and 10 mm rear, cheaper and probably just as good if not better function-wise)
3. H&R 15 mm lowering version front and rear (as opposed to 25 mm lowering that most folks use)
4. Vogtland springs (15 mm lowering front and rear)
5. Lightweight Lower Spring Kit (15 mm version)
6. ...
At least, that's what I came across when searching for lowering springs for my car. There are some other options but they lower more than 15 mm so I didn't bother as I see no point in driving "on bumpstops".
I'd say "dinan" bumpstops are mandatory with all of the above (see OEM numbers above).
I've had Eibach springs for 6k miles and, knock on wood, the shocks are fine so far, though my roads are far from perfect.
      07-20-2016, 02:13 PM   #12
MyM235i
Did some looking,
1. Dinan may be ok, Im not sure I Like the 1' rear drop for the RWD
2. Same problem with Eibach and which one would be better?
3. H&R Part number for 15mm is hard for me to figure out. I appears that part number is for the 228. At least in the NA catalog. I also can not confirm only a 15mm drop. Bee Pee is this what you have and can confirm its only 15mm and fits adaptive suspension?4. I contacted Vogtland as the EU catalog says 15mm and the NA says 19MM.They said its somewhere between. I wasn't happy with this answer to be honest.
5.Still waiting to hear from the NA lightweight distributer (supreme power) Does anyone have any experience with them?
Cheers
      07-27-2016, 11:56 PM   #13
Taunto
Car Enthusiast
Taunto's Avatar
Drives: 2016 BMW M235 X-drive
I did Dinan Springs - Car is X-drive.
I feel like the rear dropped almost an inch compared to what it was soposed to drop. Could just be me but thats what it seems.
i am Extremely happy with the springs. The Ride comfort hardly changed.
Biggest notice was it got rid of alot of the bouncyness that you get when in Comfort mode.
Sport mode is slightly stiffer, a little noticeable but not spine crushing stiff.
I personally couldn't be happier with the springs.
Tpeterson156.50
qnet681.50
      07-28-2016, 01:06 PM   #14
Tpeterson
Tpeterson's Avatar
Drives: 228i MSport/THP/MT/
I'm considering getting them,but I am concerned about a change in ride quality.My wife loves it the way it came from the factory. I'm glad you didn't notice a change in it,especially in Comfort. BTW With them installed your x-Drive looks like a RWD.
Taunto281.50
      08-07-2016, 04:23 PM   #15
qnet
qnet's Avatar
Drives: 18 Jeep Wrangler, 18 M2 LBB
That actually looks lower than I've seen on other M235i's with Dinan springs. It looks good. I have Dinan springs and bumpstops on order.
Taunto281.50
      08-07-2016, 05:14 PM   #16
Taunto
Car Enthusiast
Taunto's Avatar
Thank you.
Front lip only scrapes when i go into my underground parkade in my appartment. kinda sucks but ya.. other than that i havent scraped it yet..
      08-25-2016, 07:33 PM   #17
hoppy6698
hoppy6698's Avatar
Originally Posted by x233 View Post
To name a few:
Well, finally found the Vogtlands for 15mm, like this site:
http://www.tunershop.com/15mm_Vogtla...883946_h4.html
However, I cannot find a review for them. I'm not a fan of the 1" drop in the rear on Dinan either. I wish it was 1/2" all around to be honest. Since I want to add 19" wheels and the M3/4 LCAs.
Found H&R 15mm springs, but only on a German website. Have not found these in the US yet.
      08-26-2016, 01:18 PM   #18
MyM235i
I have done this search. I also would like a slightly firmer rate and a .5" drop all around.
Vogtland say 15mm on the EU catalog and 19mm for North America. I contacted vogtland directly and they said they will be somewhere between 15 and 19.
I didn't contact HR directly but the North American rep said the 15mm are for the 228 so I would be worried about spring rates.
Supreme power is the distributor for lightweight and they are (hopefully) getting me some answers. Lightweight is on holiday till the end of the month though.
      08-27-2016, 12:03 AM   #19
moldcad
moldcad's Avatar
Poland
262
I drive my M235i rather aggressively and fast, and I hope this (and not soft spring materiel) is the reason that my car - now 14 months old - looks much, much lower than new. I know - all springs settle, buy this is my first car that settled down that much. Just see the picture!
Piotr
      08-27-2016, 07:53 AM   #20
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Op
BMW now sell MP springs and bumpstops for m235i adaptive - warranty friendly upgrade perhaps ?
BP
      08-27-2016, 07:54 AM   #21
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Piotr
Ride height looks normal for a stock m235i
      08-27-2016, 10:42 AM   #22
MyM235i
Originally Posted by Bee Pee View Post
Op
BP
Part numbers? Drop over adaptive? Is it a kit with the bumpstops?
Cheers
