2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes F22 (228 or M235) Track setup
      01-27-2015, 05:35 PM   #23
Liquidpaper
Liquidpaper's Avatar
Drives: '15 M235i
2015 BMW M235i  [0.00]
Originally Posted by hoppy6698 View Post
Getting ready for the summer HPDEs, like you:
- Full flush, refill with ATE 200 brake fluid
- Steel brake lines (Turner Motorsports)
I want to upgrade the sway bars, but they seem too new and not enough different brands yet. I may do the first event on stock M235 suspension (vs. HR springs) to learn the car better.
Thought about an aFe or BMS intake, but others seem to be selling theirs, preferring a quieter intake. Anyone know of a drop-in K&N air filter?
I am tempted on upgrading the down pipe though.
Since it is my DD, I'll be keeping the staggered setup for now.
The stock suspension is better than people give it credit for. You should be just fine.
      01-27-2015, 11:10 PM   #24
hoppy6698
hoppy6698's Avatar
Drives: M235i, Estoril Blue on Black
Not worried about the suspension holding up, BMWs always do. More about the closing the gap in the wheel arches a bit. Either by Dinans or HRs, not 100% sure on which one yet.
      01-28-2015, 12:03 PM   #25
Liquidpaper
Drives: '15 M235i
Let me know which one you go for. I like HR, but I've seen the drop and it seems a little too much in the front.
      01-29-2015, 11:45 AM   #26
Liquidpaper
Drives: '15 M235i
Originally Posted by rwalker View Post
et38 should have more spoke clearance, but the shape may differ...
I'd not go with it unless Apex stands behind it.
Also, 18x8.5 et38 rear would look a lot like mine (IMHO, too pokey for the street).
I put this stuff into the fitment calculator and I should be fine up front (some 1 series guys run the same setup up front); If I ran ET 45 I'd need a spacer.
But for the rear, the calc tells me that my setup would be 3mm less "pokey" than yours is. What is your camber setting on the back? I'm at -1.65 right now, and I'm due in for my camber plates on Monday, so I can ask them to adjust the back, if necessary. Thanks!
      01-29-2015, 11:50 AM   #27
rwalker
Drives: the wheels off
My rear camber is stock, making it a bit more negative could do the trick for you.
Your calculator is dead-on (3.35mm to be exact ), but my wheels and tires stick out more than 3mm, so I think you'd still have some rear poke.
Of course this all comes down to taste, and my opinion is only that. I'm looking forward to seeing how it turns out in any case!
      01-29-2015, 12:05 PM   #28
Liquidpaper
Drives: '15 M235i
Oh I'm sure I'll have some poke. The issue is cost really. The ET38 wheels (which do work) are 200 bucks off and free shipping right now. That's basically a free wheel. Kind of can't pass that one up.
      01-29-2015, 12:40 PM   #29
Liquidpaper
Drives: '15 M235i
Hey, would you mind taking a couple more pictures of your rears, just so I have a better idea of what they look like? Maybe a few close up shots from 1 or 2 different angles? Thanks a bunch.
      01-29-2015, 12:52 PM   #30
rwalker
Since this is my track setup it's not on the car right now... I can accommodate the request February 7th .
Here are some more pictures, though probably not as helpful as you'd hoped.
      01-29-2015, 01:25 PM   #31
Liquidpaper
Drives: '15 M235i
Last picture is super helpful -- needed a front(ish) profile shot to see what the "poke" looked like. It's definitely not bad -- just looks aggressive, not stancenation. Thank you!
      01-29-2015, 03:08 PM   #32
Béhème
Only three things are required to enjoy this car at a very high level on track: track tires, track brake fluid and track pads.
Once you can manage to keep your lap times within the same second, only then is it time to consider mods.
Spending time and money on learning to drive, is a much better investment towards improving your lap times than mods.
      01-29-2015, 03:16 PM   #33
Liquidpaper
Drives: '15 M235i
I completely agree - spending time and money on improving the bag of meat driving the car will improve your lap times much faster that buying mods. That being said, I was having some serious issues with my fronts being chewed up from lack of front camber -- it was getting expensive and unsafe. Also, I just figured while it was on sale, I'd go pick up some lighter wheels.
      01-29-2015, 04:07 PM   #34
rwalker
more pics
      01-29-2015, 05:21 PM   #35
Liquidpaper
Drives: '15 M235i
more pics
Do your rear tires clear your rear fender? It looks like it might rub a bit.
      01-29-2015, 05:40 PM   #36
rwalker
no rubbing, but quite close
      01-29-2015, 06:00 PM   #37
Liquidpaper
Drives: '15 M235i
Great. Should be fine with 3mm less poke and some camber. Thanks a lot!
      01-29-2015, 07:00 PM   #38
ketema
Drives: 2015 M235i
I'm subscribing to this thread. Very interested in seeing what others do for the track. So far I have changed my brake fluid to Torque RT700, changed brake lines to steel, switched to Pagid RSL1 pads and Stoptech slotted rotors. I have KW DDC Coil Overs and Ground Control Camber kit about to be installed.
      01-29-2015, 10:25 PM   #39
rwalker
Yes!
      01-30-2015, 08:35 AM   #40
Béhème
For those who haven't seen this yet, enjoy:
      01-30-2015, 08:52 AM   #41
Béhème
Please let us know how you like the Pagid RSL1.
      01-30-2015, 07:59 PM   #42
ketema
Drives: 2015 M235i
Love it. Now. It took some getting used to. It grabs very quickly. I was constantly braking too early until I got used to them. Down points are they are very noisy, but on the track who cares. I switch back to stock for regular driving. Overall I feel my braking ability is much greater than stock. When I graduate from the stock Michelin Pilot Super Sports to a real track tire I expect significant improvement again.
      02-02-2015, 12:48 PM   #43
Chris in Japan
Drives: BMW M135i on order
My car is an M135i so pretty similar.
Here is what I have done:
Quaife LSD.
TCKline racing coilovers w/ camber plates
Racing dynamics sway bars
Endless RF650 brake fluid
SS brake lines
Endless MX72 pads
Nangkang NS2-r soft compound tires 255/40/17 square
Team Dynamics Pro Race 1.2 17x8 40offset
Wagner competition intercooler
Downpipe w/ 200cel sportcat
ER Chargepipe
BMS Intake
Racing dynamics R35s tuning
The car is now an absolute blast to drive on the track which I do every weekend for 8 months of the year.
The Quaife (or any LSD) is a must do. The TCKR coilovers coupled with the sway bars may be a bit much for a daily driven car, but works great for me. The TCKR camber plates are brilliant.
Not sure how happy I am with the Endless pads. They do offer better pedal feel, and better initial bite , but they do fade eventually. Will try something different once I toast these.
The NS2-r's while not the best tire out there offer repeatable lap times as they dont overheat like the stock PSS's. Will probably try Direzza 03G's next, as I love my ZII's which I use for the street.
Next up is a P3 gauge as entering the secret menu every time is a real pain.
      02-02-2015, 01:04 PM   #44
Liquidpaper
Drives: '15 M235i
Quaife LSD.
SS brake lines
Endless MX72 pads
ER Chargepipe
BMS Intake
Looks good. I'm getting alot of stuff done this month:
Ground Control camber plates (install today)
APEX ARC-8 18x8.5 ET 38 in Hyper Black x 4; Direzza II 255/35 x 4
Challenge Stainless Lines
ATE 200 fluid (already have in)
Porterfield R4-S pads
(and just for fun) M-Performance Exhaust (great deal on ebay today).
Thing is, I live in LA in an apartment, so I don't have a garage to switch stuff out, so I kind of have to compromise. Hence no dedicated track tires or pads. Both seem do do pretty well so far (have Direzza's on right now, but staggered, and the stock M235i pads are actually pretty damn good). Also, as I mentioned above, I have a P3 in and it is great. Totally worth the money.
Everything should be installed before the end of the month, so should be pretty interesting...
Future (next) upgrade will be the M-Perf LSD. the eLSD is actually very good, but I do want to upgrade eventually.
