02-03-2019, 08:51 PM | #23 |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
18x9.5et45
Project Car: DF Goblin
-Built LSJ-T 2021 C8 Corvette 1LT 2021 Model Y Performance |
02-03-2019, 08:52 PM | #24 |
Rep 1,303
Wish they had the et50 in stock, but they didn't have an ETA when they would be in stock again
02-04-2019, 01:41 PM | #25 |
Rep 197
I currently am running e50x19 rear with 265s and dinan springs no problem. Just had it installed last week and put it through the test (i.e. San Antonio roads) with ok problems in the rear. Now the 235s up front are a different story. She's rubbing a lot on the huge dips in the road.
16' M235i Active Autowerkes Stage 2 Tune/DP/FMIC/CP - Dinan CAI/Lowering Springs - 19x8.5/19x9.5 Forgestar CF5V Bronze Burst
02-06-2019, 06:01 PM | #26 | ||
Rep 170
Current: 2019 M2 Comp, Coilovers, Camber Plates, Rogue SSK, AA Single MP, BM3 Stg 1
Sold: 2015 M235i RWD, MHD Stage 2, FBO, MPE, XHP, HPD5Evo | IG @sea_m235i |
02-06-2019, 07:53 PM | #27 | |||
Rep 197
02-07-2019, 12:30 AM | #28 | ||||
Rep 170
35[/QUOTE] Hmm....that's what I'm running. Do you think 225s would correct this issue? Or is it more severe than that? Do you regret putting them on and do you have plans to correct it?
02-07-2019, 06:12 AM | #29 |
Rep 1,303
8.5” wheels need an offset between 39-42 to clear the fender on springs is my understanding of running 235s. My 19s I had on previously we’re et39 and I’m pretty sure they would’ve barely tucked under the fender. If not, rolling the inner fender would have definitely solved the issues.
02-07-2019, 07:27 AM | #30 | |
Rep 521
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers) 2014 M235i MT, BSM, MPE, Dinan Springs (Sold) |
02-07-2019, 09:05 AM | #31 | ||
Rep 1,303
B58togo808.50 |
02-07-2019, 08:13 PM | #32 |
Newer 2er
296
Rep 474
Drives: 2017 M240i (Sold)
Been running MPS4S 235s 18x8 et 40 front and 265s 18x9 et 50 rear on Dinan Springs & bump stops with no rubbing or any issues.
2017 BMW M240i (Sold)
2021 F-150 Raptor 2017 Porsche 718 Cayman S 2017 Audi Q5 |
02-08-2019, 02:11 PM | #33 | |||||
Rep 197
[QUOTE=sea_m235i;24346316]
sea_m2c82.00 |
02-16-2019, 05:03 PM | #34 |
Rep 32
Loved the setup of your car... definitely served as inspiration for mine!
02-24-2019, 08:52 PM | #35 | |
Rep 1,369
02-24-2019, 09:59 PM | #36 |
Rep 1,303
Best thing to do right now would be measure 5mm against the outer tire wall (straight and full lock left and right) and see if it hits the fender. Will give you a rough estimate if it’ll work or not
07-05-2022, 11:15 PM | #37 | |
Rep 7
