07-18-2019, 11:13 AM | #1 |
Rep 336
Thoughts on heat exchanger for b58
Anyone running a heat exchanger like the CSF specifically on a B58? I've heard lots of positive things about the b58 and minimal heat soak. Is it worth it?
07-18-2019, 12:52 PM | #2 |
Rep 5,369
The CSF heat exchanger like they use on the M3/M4 won't work as the heat exchanger on the B58 is built directly into the intake manifold. The S55 is a separate system.
07-18-2019, 01:25 PM | #3 | |
Rep 336
07-18-2019, 01:39 PM | #4 |
Rep 2,214
A worthwhile upgrade imo, no different than a FMIC. Can never have "too much cooling" when it comes to intake temp control.
If I had a B58, I'd be doing this along the way once I started added power.
07-18-2019, 03:25 PM | #5 |
Rep 5,369
Ahh I see now. For me personally, I wouldn't. That's a lot of money and work to reduce IAT by only ~20-30 degrees and the worst case is IATs get into the 120-130 degree range.
But what makes me most resistant is modifying a BMW liquid cooling system. My concerns: 1) How did CSF validate that putting a much thicker exchanger in front of the radiator won't impact cooling of that system or cause the fans to work harder? Those fans aren't cheap. 2) How did CSF validate that the OEM intercooling system water pump can handle the increased capacity in the long term? 3) Leak potential. 4) I've never heard of B58 owners complaining of heat soak issues or excessive IATs. Though far more complex, the stock B58 intercooling system is much better at maintaining consistent and lower IATs.
07-18-2019, 03:40 PM | #6 |
Rep 400
For stock, I'm not sure it's necessary.
If you add a lot of power, then you may need to consider it. Last weekend was 95F+ and the intake air temp was around 140F when running Auto X. (150F when idling with AC full blast. as soon as the car moves, temp went down) |
07-18-2019, 04:09 PM | #7 | |
Rep 2,214
But as for the blocking of the rest of the engine's radiator, condenser etc. I think that's a valid point. Would love to see some data to back up the upgrade as well.
07-18-2019, 04:29 PM | #8 | |
Rep 400
(coolant flows to AC condenser first, then to CAC) To upgrade the cooling for CAC, low temp radiator needs to be beefed up. (also bigger fan, bigger water pump) I'm not sure how they can upgrade the CAC in the intake plenum without modifying the intake manifold. |
Dylan861330.00 |
07-18-2019, 04:37 PM | #9 | |
Rep 3,494
For me, only if I had evidence it was going to make a difference in a specific way. For example, I take my car to the track, but my sessions are short, so I don't have the need there. Elsewhere, it's not going to do anything but lighten my wallet.
This diagram from Bimmerworld's site shows more of radiator #1's world:
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF Last edited by dradernh; 07-18-2019 at 04:49 PM.. |
07-18-2019, 06:00 PM | #10 |
Rep 336
I'm still on a stock turbo, but running BM3, intake and midpipe upgrades. I drive pretty aggressive and eventually may do midpipe. Also, I live in TX which, well is hot. Lol.
I added a FMIC on my previous car, a Volvo S60 r-design, and the difference was clearly noticed. But as everyone seems to be noting, it sounds like BmW did this engine pretty well in regards to cooling. Cost vs benefit vs cool factor ratio in play here lol. |
07-18-2019, 06:41 PM | #11 | |
Rep 3,494
I will say that once the car was fully up to temperature on the autobahn (during a summer in Germany when the temps were 85°-90° every day), I didn't notice any significant drop-off in performance on those highway runs. My top-speed run was 152 MPH at ~80° ambient, so whatever power it was pulling didn't slow me down too much. However, it may have been doing that and I didn't pick up on it.
07-18-2019, 09:43 PM | #12 | |
Rep 400
CAC is inside of this intake manifold. This is difficult to be upgraded. |
dradernh4371.50 |
07-18-2019, 10:12 PM | #13 |
Rep 3,494
I've looked at that and wished that the interior unit was shown on the diagram, too.
07-18-2019, 11:12 PM | #14 | ||
Rep 336
07-19-2019, 12:10 PM | #16 | |
Rep 3,494
Where did you locate this image?
07-19-2019, 02:25 PM | #17 | |
Rep 400
See attached. |
