Looking to buy a used 228i - What should I watch out for? |
07-07-2019, 08:40 PM | #1 |
Rep 34
Hello everyone,
New on the forums here, I'm looking into getting a 2 series, 228i 6MT in particular. From what I've gathered, it seems that the N20 pre-2015 may have timing chain issue, but how widespread is it? What other things should I also look for when checking out the car? Thank you guys! Please be nice to the bimmer noobie! Jason |
07-09-2019, 12:38 PM | #2 |
Rep 242
more of an annoyance than anything serious - check for the cold start exhaust noise. There's a small flap that's supposed to stay closed until the engine heats up and in some models the flap rattles. There's a recall for it.
Seth |
07-09-2019, 12:45 PM | #3 |
Rep 4
Does the recall apply to the M235i as well? I just took mine to the dealer because it does the annoying rattle upon cold starting. I showed them a video with the sound because I knew they couldn't replicate it at the dealer after I drove it there. They shrugged me off and said "everything's fine." Very frustrating.
07-09-2019, 02:44 PM | #4 |
Rep 1,219
Drives: 2015 M235ix
With any used car, the sweet spot is at 3-4 years old, which makes the model year you are looking for 2016 or 2017. There are very few 6 mt vehicles out there for any year, so you may have to cast your net widely geographically and you won't be able to be picky about options and exterior/interior colors.
That said, the good thing about the 2'er is that it continues to be the most reliable BMW in all model years. The down side (for a buyer) is that it has the lowest depreciation rate. |
07-11-2019, 11:31 AM | #5 | |
Rep 34
07-11-2019, 11:43 AM | #6 | |
Rep 922
Drives: '21 F87 M2C 6MT
Garage List 2015 MINI Hatch 5-door [0.00]
2021 BMW M2 Competi ... [9.67] 2023 BMW X5 xDrive40i [0.00] 2017 BMW X3 xDrive28i [0.00] |
my 2015 228i xdrive 8AT has been flawless, and i'm about to turn 70K miles. i solved the rattle-trap exhaust problem with an active autowerk axle-back exhaust. my only other compliant is the 18" run-flat tires are highly prone to blow-outs, so either look for 17" wheel/tire combo, or be prepared to swap out the run-flats if you have crappy road conditions in your area. in my case, i'm not giving up the run-flats because there's no way i'm getting out of the car to change a flat on any portion of my DC-area commute which is 90% of my driving. all-in-all, after owning 9 BMWs since 1990, this is far and away my favorite!
my garage: '23 G05 xDrive40i m-sport; '21 F87 M2C, 6MT; '17 F25 x-drive28i SAV; '15 F55 mini hatch 5-door retired: '87 E30 MT 'vert; '92 E36 sedan; '99 E36 MT 'vert; '06 E90 x-drive sedan; '07 E83 x-drive30 SAV; '09 E91 x-drive wagon; '12 E89 Z4 MT M-sport; '15 F22 sport line Last edited by happyjack; 07-11-2019 at 11:48 AM.. |
07-11-2019, 12:34 PM | #7 |
Rep 2,873
Speeding tickets will be the main thing to watch out for
But for mechanicals, I've not seen much on a/t too serious. The wiring harness to rear lights before c.10/16 will burn out (inadequate ground wire, simple fix and may be extended-warrantied). With an MT you really should get a PPI for the clutch/tranny - dual-mass clutch gets some bad press. The waste-gate is integral with the whole turbo housing, and if they go bad you replace all the expensive stuff - more incentive for a real PPI. Batteries may be getting to the end of lifespan, but there were many 'lemons' that went early and got replaced already. Some c/o charge-pipe failures, idler-pulley fails, and gunk on the intake valves. Also pays to check carefully for collision damage, since this can be hidden from carfax. The only issues mine has had are the rear taillights (and some extremely rapid brake wear, but I have some 'suspicions' that driving style had a lot to do w/ that). Make sure to check the BMW CCA classifieds, as they often have MT versions, and I assume the sellers are more likely to have taken good care of them. |
07-11-2019, 01:07 PM | #8 | |
Rep 3,497
Maynard3848.00 |
07-11-2019, 01:17 PM | #9 | |
Rep 34
Also, I'm in Canada, looks like I won't be able to take advantage of BMWCCA, but thanks for the advice anyways! |
07-11-2019, 05:58 PM | #10 |
Rep 2,873
PPI is a pre-purchase inspection, usually by a good indie repair shop, or a friend if they really know what's up (with a 228, I'd think you'd need scan tools that aren't often found in a home garage). I've not used one myself, but I think you can get one for a few hundred, perhaps less if you will be a future customer for them.
c/o is 'complain of' (Some complain of charge-pipe failures...). Good luck on the search, I've loved my 228, sure you will too once you find it. |
rainfall161.50 |
07-11-2019, 07:19 PM | #11 | |
Rep 34
Would a good shop be one that specializes in BMWs or Euro cars? In any case, I went to take a look at a 228 today, poked around with all the accessories and features and stuff too. I started the car and recorded a clip of it idling. Does anyone know if this sounds about normal? Thanks! |
07-11-2019, 07:37 PM | #12 | |
Rep 3,497
Are you in the Toronto area? If so, there's one shop on this page that may be of interest: https://www.bimrs.org/Regions-outside-US.html. You can look around the site to see what the members are about - mostly it explains why they're legitimate alternatives to the BMW dealers.
07-12-2019, 08:16 AM | #13 |
Rep 25
JaZoN_XD, I bought a 2014 CPO (A/T) with 30K miles 2 years ago. I now have over 60K miles. No issues or problems to report. It continues putting a smile on my face, and you should feel it at the Tail of the Dragon! Great car, great balance, good gas mileage on the highway if you control your right foot. And fast if you do not control your right foot! Highly suggest a radar detector.
happyjack1657.00 |
07-12-2019, 09:49 AM | #14 |
Rep 286
OP, I purchased my CPO 2014 228 M/T, M-Sport with 9k miles 2 and a half years ago. Currently sitting at 45k miles, only issue was the thermostat went bad. Replaced under warranty.
From what I know the three weak points are In tank fuel pump timing chain thermostat All three parts have an extended factory warranty on them by BMW and will be replaced if failed. I have three separate letters from BMW stating so. That aside, it's a wonderful car and great daily driver. |
07-12-2019, 05:29 PM | #15 | ||
Rep 34
P253.00 |
07-12-2019, 07:19 PM | #16 |
In search of the perfect cup of coffee
152
Rep 213
I bought my '15 228i Conv CPO last year with 17,600 miles on it. It's now got 26,200 miles on it, including a recent 5,300 mile round trip across country and I've not had one problem with it.
EDIT: On the 5,300 mile round trip, I averaged 30.5 mpg. |
07-13-2019, 08:34 AM | #17 |
Rep 922
in some weeklong trial runs using eco pro i was able to get 34-35 pretty consistently...but i rarely use it. i'm probably 50-50 comfort and sport mode. i still average around 28 mpg.
my garage: '23 G05 xDrive40i m-sport; '21 F87 M2C, 6MT; '17 F25 x-drive28i SAV; '15 F55 mini hatch 5-door retired: '87 E30 MT 'vert; '92 E36 sedan; '99 E36 MT 'vert; '06 E90 x-drive sedan; '07 E83 x-drive30 SAV; '09 E91 x-drive wagon; '12 E89 Z4 MT M-sport; '15 F22 sport line |
07-15-2019, 07:19 AM | #18 |
Rep 34
07-17-2019, 02:38 PM | #19 | |
Rep 242
There is no recall per se, it's just a TSB. I would get the number but I don't have access to the BMW service system. I assume most people just take the car in for service and it takes only 15 min for a replacement and a prayer it doesn't come back. The rest either cut out the valve altogether at a muffler shop or replace the exhaust to eliminate it. Seth |
07-17-2019, 08:56 PM | #20 |
Rep 922
i'd estimate my commute, generally, as 60% free-flowing highway miles, 20% rolling highway traffic below 30 mph / stop-and go, and 20% in-town.
today was a fairly $h!tty commute...both going in and coming home. i reset my MPG calculator and rolled eco-pro round trip...and could only manage 28.8 MPG today. DC beltway can suck it.
07-17-2019, 09:35 PM | #21 |
Rep 772
Drives: 2015 435i grand coupe xdrive
Buy low mileage and immediately disable start stop. That kills these engines. Other than that should be a good car.
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current) 2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD) 08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD) |
07-18-2019, 05:13 AM | #22 |
Rep 1,219
Drives: 2015 M235ix
What evidence is there that start/stop harms engines?
You would need to do a controlled study of a large number of otherwise identical vehicles except for start/stop being disabled or not. The feature is common across many manufacturers these days. Yes, intuitively it would seem that this function would put strain on the engine, but without actual data . . . |
