07-05-2019, 01:57 PM | #1 |
Rep 277
Drives: 2018 230i MSport
New Wheels and Tires Help
I know there is tons of info on this forum, but most of it has just led me to more questions on the best way to get the set up I want. I daily my 2018 230i, and only occasionally go out for more spirited drives. The roads here are rough and poorly designed with steep inclines into parking lots.
Right now my car is on DINAN springs and stops, front and rear with 18" run-flat factory staggered setup. It's a little rough over road imperfections, and the wet traction leaves a bit to be desired. Unless I cut hard entering exiting the main road, scraping is a real possibility. What I want is to get a smoother ride with better wet and winter traction without getting winter tires. I'm stationed in south Alabama so snow is very rare, but it does get below freezing, and it rains a lot. Also I want to raise the ride height while keeping the lowering springs for better clearance. In a perfect world I would like to get 19" VMW wheels with a larger offset to sit more flush with the fender. Use tires with a taller sidewall to maintain 18" ride comfort, and increase the ride height with a larger wheel/tire diameter. Effectively this would increase the ride height by maybe 1/4 to 1/2 inch, fill the front to back fender gap more, and not sacrifice comfort caused by a thinner sidewall. My questions: - Are 19" wheels a noticeably rougher ride? - Can I safely increase the sidewall height of the tire some, and not rub without rolling fenders or using lots camber? I've never dealt with tire and rim changes before, so I'm trying to learn as I go. Most of what I've read here are people looking to fit wider tires on the front or rear, but I haven't found anything dealing with taller. Any advice would be appreciated. Thanks in advanced! |
07-16-2019, 11:39 AM | #2 | |
Rep 507
Current Tire Specs ? 19"s are a noticeable difference from 18s You will certainly rub if you increase to 19's and larger sidewall. I have the DINAN springs on 19's with 255/30/19 at the rear and 225/35/19 up front and any larger i would rub. What i would suggest is get 19's and ditch the run-flats, run-flats are louder and more harsh IMO they also handle like garbage. Get AAA or the BMW mobility kit Hope this helps
07 e90 335xi- Sold, 09 X5- Sold, 12 e92 335 xdrive - Sold 11 e92 M3- Sold, 15 M235-Sold,07 e90 335xi (current daily), 10 Atlantis e92 M3 (current) Way to many mods to list
07-16-2019, 12:15 PM | #3 | ||
Rep 242
Just remember your rim size will dictate tire selection. Not all brands/blends are available in all sizes. Seth |
08-18-2019, 05:19 AM | #5 |
Rep 525
17" wheels will get you a softer ride and less risk of tire and wheel damage on potholes. Non RFTs will do more of the same.
All season tires will get you better wet traction. Filling the wheel wells for appearance sake is not a good idea. |
09-02-2019, 03:18 PM | #6 |
Rep 242
Compared to an 'extreme performance' summer (basically a track tire) yes as they have minimal voids in tread design, but a UHP summer will have better wet than a UHP A/S of the same generation.
As for Max vs. UHP in the wet, there is no Max in A/S, it's just summer, and those have amazing wet traction (conti EC sport for example). They are considerably more expensive a category of course. Seth |
