07-04-2019, 10:26 AM | #1 |
Rep 211
Is this normal or is a bearing or something need checked out? Sound is only present at hard throttle with revs above 5000. See vid below, although it sounds a touch more metallic in person...
07-12-2019, 12:21 AM | #2 | |
Rep 133
have it checked out immediately and stop driving it! |
07-12-2019, 07:35 AM | #3 |
E4 Mafia
323
Rep 412
Drives: E30, E36/5, E46, F22, F30
Garage List 1990 BMW 325i [0.00]
1998 BMW 318ti [0.00] 2003 BMW 325i [0.00] 2015 BMW 335i [0.00] 2015 BMW M235i [0.00] |
I didn't hear anything :
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k)| '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k) Bring back the purple M stripe |
07-26-2019, 08:56 PM | #4 |
Rep 211
Quick update... for anyone who hears that sound in upper RPM band at full throttle, def get it checked. Turns out I need a new transmission (thankfully under warranty). It's inbound from Germany and should be here in a week or two. Car drives totally fine and has been great, just the slightly noticeable squeal above 5k - mostly in 2nd but other gears as well for the 8AT. Tech mentioned the fluid was pretty nasty so suspect the previous owner drove it pretty hard... plugs were also replaced around 30k miles (before I bought it) which is another sign of hard use.
Any recommendations on other things to check or preventive maintenance to do if car was run pretty hard? (it's in mint shape inside/out and was a FL car so looks really solid all around). Def gonna do a Blackstone oil analysis, but anything else at roughly 38k miles? |
09-08-2019, 01:15 PM | #5 |
Rep 8
How could a transmission produce such a sound?? Did the dealer told you what specifically was wrong with the transmission? Was the problem solved after the transmission swap?
09-08-2019, 03:26 PM | #9 |
Rep 211
No additional detail known... was diagnosed in a day and had green light from BMW engineers 2 days later.. got car back for a week while new trans shipped from Germany then was installed in 1-2 days. Dealer - Fairfax, always great service
