07-01-2019, 02:29 AM | #23 | |
Rep 318
When you wrote "Add throttle and the nose actually pulls inwards towards the turn." I thought you were talking about the LSD affecting the ability of the front tires to turn the car in. Whereas I think you're comparing cornering while accelerating at a pace that would cause the rear to slide without an LSD but not with one. Of course the LSD car will get around and out of the corner faster in this particular situation. So what? Speed only matters on the track. On the street, my idea is to have the most fun at the lowest speed. That's why I prefer the lower speed / lower acceleration slides possible with an open differential and all season tires. I have no trouble doing smooth, controllable slides in Sport+, and I don't understand the problems some people claim they have with them. One potential explanation is a difference in definition of "slide". For me that means having the rear wheels outside the track of the fronts by a foot or two at the most - definitely not enough to have the nannies step in. Maybe others think sliding means the car at 45 degrees to its path and full opposite lock on the steering wheel, which I know nothing about on pavement (though just after I got my license I had a lot of fun learning how to do that in my dad's 59 Plymouth on the local horse track when no one was around). Possibly another difference is in how close we are to the traction limit when we want a slide. I like to be using up most (80 - 90%) of the available traction for turning before adding a bit of gas to induce oversteer. If you want to slide from using only 50% of traction for cornering, an open differential may well be uncooperative. I wouldn't know as I've never tried that. Or maybe it is just the tires. In my hands the Pirelli runflats do controllable, gentle slides in 40 - 70 mph corners, and the fun of those slides makes up for all the negatives of those tires.
18 M240i RWD auto
Previous: 01 Z06, 99 323i Last edited by albertw; 07-01-2019 at 02:41 AM.. |
07-01-2019, 07:24 AM | #24 | |
Rep 294
Drives: 2019 M240i Coupe RWD
And if the M235 making 360 degrees around the pad isn't a sustained drift, I don't know what is! I am sure it didn't have a LSD. |
07-01-2019, 09:41 AM | #25 |
Rep 294
FYI, I found in another thread that with DSC off, that is the only mode where the "eLSD" or Automatic Differential Brake is activated.
So while it may not be as good as a real LSD, it may be effective enough for some drifiting. |
CP911986.50 |
07-01-2019, 10:13 AM | #26 | |
Rep 5,372
When I ordered this car, I specifically ordered it without the LSD so I could evaluate if the car really needed it as I knew the eLSD was pretty good and the nanny intervention in Sport+ fairly acceptable compared to other makes. At the time, the LSD was a $3,900 option which was bonkers to me. Overall, I thought the car was fairly well-sorted but wasn't exactly blown away by the handling performance. It was good, but felt a bit disconnected between the front and rear axles. Under heavy throttle in 2nd and going in a straight line, I could feel this weird rocking sensation coming from the rear axle while in Sport+ and DSC Off (others have reported the same behavior). The traction, or lack thereof, under heavy throttle in 1st and 2nd was somewhat poor and made me think the PSS 245 rear tires weren't wide enough. I could coax throttle oversteer in Sport+ and DSC Off and could control it, but it felt a little off plus when it did it, forward momentum was generally lost. Like you though, I thought the non-LSD setup was pretty good and didn't understand why people gushed over it. I read all the posts about the LSD but often questioned how it could make such a dramatic difference. Years ago, I swapped a 350Z viscous LSD into my G35 and it didn't make a huge difference so I couldn't see why this clutch-based LSD would be God's gift to the 2 series. Fast forward two years. I decided "what the hell", I needed a new mod thus it was time for the LSD and prices had fallen dramatically. I got it installed for around $2,500. I broke it in was recommended and then started exploring it's capabilities. I'm not afraid to admit that I was wrong in doubting the validity of the LSD claims. It's a like a different car. The issues noted above were remedied and the car felt like a proper sports coupe. Throw in my square 245 setup and Dinan rear springs (MASSIVE improvement in rear axle control) and this car has high limits, but not so high that you can't explore them on a B road. I'm not interested in cars that are extremely fast and have limits you can't explore on a daily basis.
MassNerd171.00 |
07-01-2019, 10:17 AM | #27 |
Rep 5,372
You're right on both accounts. The LSD will make the drift way more controllable, fluid, and elegant. Also, you can maintain a lot more forward momentum with the LSD and feels much more natural and controllable as you can modulate it with the throttle. With the eLSD, it simply feels like the car is rotating on it's axis and to me, felt far less controllable.
07-01-2019, 06:38 PM | #28 |
Rep 213
Back in 1995 my salesperson had to fight with Munich have my Club Sport built without a sunroof. In that case it was an option but the factory still tried to force me to take one. My salesperson stood firm and mine is one of less than ten Club Sports that didn't get stuck with a hole in the roof.
2014 M235i
2015 X1 xDrive28i M Sport 2009 Cooper Clubman 1999 Wrangler Sahara 1995 318ti Club Sport |
07-01-2019, 06:42 PM | #29 |
Rep 213
2014 M235i
07-02-2019, 09:20 AM | #30 |
Rep 422
07-04-2019, 12:30 PM | #32 |
Rep 109
07-07-2019, 09:51 PM | #34 |
Rep 1,369
Yes, it's easier to put it into a ditch or a tree with the LSD *if DSC is disabled*.
rainfall161.50 |
07-09-2019, 11:30 AM | #35 | |
Rep 5,372
With the DSC off, you've got no nannies. Once the back end is sliding, you're on your own, whether it's the eLSD or LSD in the back. Most younger folks have never had to drive powerful cars without stability control so they are less in tune with a chassis when they turn them off and simply overdrive the car and get in over their head. These cars make a lot of torque in the low rpm and midrange and you must be careful because turbos can have an on/off nature depending on throttle application and load thus the boost on-set torque surges to the rear tires need to be considered.
Dylan861330.00 |
07-09-2019, 08:19 PM | #36 | |
Rep 744
There I go again expecting people to know how to handle a vehicle before they get in the drivers seat...
07-10-2019, 05:33 PM | #37 |
msej449
514
Rep 717
{Most younger folks have never had to drive powerful cars without stability control}
and many of us who have, like me, are still prone to forgetting how much intervention there is, even in SPORT mode: here's start of a driver training course I attended at Goodwood where the first ting they do is just turn off DSC for the first time and just get you to do a quick start: Initially, it's frightening. After half an hour, you actually start to understand how to handle the car with finesse. But to disable DSC on a public road for the first time, without having done some training like this and not understanding the implications is risky. Obviously, this is on a wet track to amplify the effects, but still relevant. The cars are Euro M140i without LSD. Doing a reverse J-turn was real fun - I didn't think it was possible in an auto, but it is. And useful if I ever encounter a road block hijack, obviously.
2023 Peugeot e-208 GT (electric) Last edited by msej449; 07-10-2019 at 05:41 PM.. |
harma24402.50 |
07-21-2019, 09:10 AM | #38 |
Rep 2,214
Pfft. I drove a '93 Safari RWD w/ open diff for 5 years as a DD, in the snow and all!!
Agree on the fact that these cars feel unsafe with DSC-off, and open diff. I've compared myself and it's freaky, imo. With an LSD, DSC-off gives you the most control, with least mitigation. If you have good tires like PSS/PS4S then you're not going to just arbitrarily spin out because you're "new", just be ready to let off of the gas and counter steer. Tip for people new to power oversteer - RELAX, step into it slowly, be ready to counter steer, and let off as soon as something doesn't seem or feel right.
07-22-2019, 08:07 PM | #39 |
late registration
11
Rep 33
with lsd the colors are more vivid and everything is so much deeper.
as for the car, rwd + lsd + dsc off just make for a smile. any rwd car, really.. dancing with oversteer just makes you happy. and that's why we own these things, right? cause they make us smile.
17 m240i | 16 scion im | 15 subaru brz | 05 honda civic | 06 scion tc | 95 mustang gt | 89 chevy s-10 cameo
Dylan861330.00 |
07-22-2019, 09:44 PM | #40 |
Rep 1,369
Well said. Thread can now rest.
07-24-2019, 09:19 AM | #41 | |
Rep 5,372
Assuming you've got great tires, being able to use more throttle in a turning situation and hammering it WAY earlier when coming out of an apex is huge benefit. Without the LSD, the back end always felt twitchy and loose, as if it would want to lift up, slide, and roast the tires. With the LSD, the same situation is met with squat, tons less spin, and a car listening to your throttle and steering inputs.
