07-15-2019, 09:26 PM | #23 |
Rwelch
Rep 11
I have experienced air conditioning ceasing to blow cold air after an hour or so highway driving in hot temps. I did not have the air on max cooling when this occurred.
07-16-2019, 06:17 AM | #24 |
Rep 3
Evap Freeze
Once the evap is frozen and occluded, no a/c setting will work. Ice has to melt so air can exchange its heat withe refrigerant in the evap.
I am puzzled as to why the current low temp setting of my evap would suddenly cause it to freeze; after 3 and 1/2 years of normal function. Just don't buy a software fix, especially one that will reduce cooling capacity. This car would consistently keep 38F at the center register. Could it be that the drain in the evap box has plugged? Long shot. |
07-16-2019, 08:54 AM | #25 |
Rep 400
Evap freezing is very complicated issue and not very easy problem to replicate.
It needs certain ambient temp/humidity, temp setting and blower speed. Even with perfect condition for freezing, freeze probe is there to prevent it while having the most cooling capacity possible. I think it occurs on random cars. (fairly small percentage I guess) For those who have the issue, they just update the software. (cheap/quick fix) Drain plug could be an issue. Although you may see water pooling somewhere inside for that case. It can be the evaporator coating, which may be worn off now. So the water drainage from the evap fins are not as good as before. If the problem consist or see any degradation of AC performance, visit dealer ASAP before the warranty expires. It may be the hardware issue (faulty freeze probe, loose probe etc.) Also, slightly low level of refrigerant charge can be the cause of freezing. |
07-16-2019, 01:03 PM | #27 |
Rep 310
Agreed. My SA said if my software was not the current version then the update should work. If not he was going to have to change out a part. Something to do with the Evaporator but I didn't pay much attention since I was pretty sure the software needed an upgrade.
07-16-2019, 03:32 PM | #28 |
Rep 2,214
Happened to me for the first time, drove a LOT that day, by the end of the day, I was thinking my condenser may have been punctured or something.. Next morning, working mint again! lol
07-16-2019, 03:51 PM | #29 |
Rep 400
It seems this is happening to decent number of cars.
Here is a quick tip if it stops blowing air. (from frozen evaporator) Turn off AC compressor by pressing 'AC' button. (light should be off on AC button) Keep the blower running at medium to high speed for 5~10 minutes. It will thaw quickly and AC can start working again normally. (you can turn on AC after the air starts blowing again from vents) No need to suffer in a hot weather for long drive. Turn off AC for few minute, then you can have cold air blowing again. Use recirc mode until it gets fixed at dealer. (it freeze less in recirc mode) Keep the blower speed higher than usual. (if too cold, raise the temp setting) This is obviously a temporary solution. Visit dealer ASAP. Ask dealer to check the freeze probe reading when AC is running as well as the refrigerant charge level. |
07-21-2019, 04:20 PM | #31 |
Rep 121
07-21-2019, 09:34 PM | #32 | |
Rep 1,241
If not a dirty or clogged filter, it is likely something else restricting air flow from efficiently passing over the coil or perhaps the coil itself has become dirty and caked up with dust, insulating it from the warm air passing over it. These systems are not that complicated, so I can't imagine what else it might be... If it's freezing over, that means you have refrigerant and the compressor is doing its job. My bet is restricted air flow or a very dirty evap coil.
CP911
07-22-2019, 06:07 AM | #33 |
Rep 115
Literally just had this happen to me yesterday during a 95^F day.
My typical driving in this car is less than 30 miles. I was on a 50 mile trip, and usually have the car set to auto around 70^F. On this trip, my A/C performance started to gradually degrade so I pressed the MAX A/C button. To my surprise, nothing was really working. I eventually resorted to pulling off on a side street, turning the car off for a minute, and then turning it back on. Worked fine at this point. I do have a third party warranty. Guess I'll need to make an appointment soon.
2014 M235i
