2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications Removing overhead console F22
      05-15-2019, 05:47 PM   #1
CineNate35
CineNate35's Avatar
Drives: 2015 228i XDrive
Hey folks,
How is the overhead console removed? I'm swapping out the lighting portion and I don't see anything specific for the F22.
Thanks!
      05-16-2019, 08:09 PM   #2
wt888
Drives: none
Use a plastic pry tool to pop off the rear half covers.
Then use a metal screwdriver to pry the two rear spring "V" clips to the side, (or center, can't remember but it's obvious - pry against resistance) and use a 3rd lever to push the rear down. I believe the front end slides down and out. Looking for the metal "V" clips is the key.
