05-01-2019, 01:03 PM | #1 |
Rep 61
Help with Lowering springs
Hey guys, i recently got a set of Rotiform rims in 19x8.5 et 35 all around. Looking to go for some lowering springs but i dont want it to be rubbing or anything, which set of springs do you guys recommend for these specs?
Btw car is a 16 m235i xdrive |
05-20-2019, 07:19 AM | #4 |
Rep 129
Or you can use Eibach Pro kit, mid lowered, will have more comfort and no- issues for daily driving.
05-20-2019, 10:22 PM | #5 |
Supreme Allied Commander
3843
Rep 54,376
Drives: F80 M3
You will want something with the least amount of drop, but with the x-drive your choices are limited. If you dont't rub now with a full load, then you shouldn't rub lowered.
06-02-2019, 09:46 PM | #6 |
Rep 243
06-14-2019, 08:33 AM | #7 |
Rep 197
What tires do you run?
I am on dinan springs (1/2" front & 1" rear) with 18x7.5et33 225/40/18 fronts and 18x8et37 245/35/18 rears... Have maybe 5mm or more before i maybe rub in the rear. Fronts i have maybe 8mm left.. OEM wheels with spacers, for now...... |
