04-30-2019, 02:55 PM | #1 |
Rep 310
BMW Sport Display and Dinan Sport Tuner
Does anyone know if the BMW Sport Display will show the additional HP and Torque being generated by the Dinan Sport Tuner? I wasn't sure if BMW would recognize the extra HP/Torque or not.
I just installed it and have it set at Sport+ which should be good for 20 HP and 25-30 lbs of Torque. However my Sport Display Gauges show STOCK numbers. I am not sure if the Tuner is not working correctly or if the Sport Displays will not pick up the change. Any advice is appreciated. |
04-30-2019, 02:59 PM | #2 | |
Budget Enthusiast
243
Rep 197
Drives: 2017 230i M-Sport
2017 230i // Estoril Blue II // M-Sport |
04-30-2019, 03:00 PM | #3 |
Rep 8,942
Sport displays will not pick up the change. You need something like P3 with physical boost tap reading.
05-01-2019, 05:54 PM | #4 |
Rep 310
Pressure readings ??
So when I am in Sport+ mode the pressure reading is negative 3.8-4.08. I can get the peak reading up to 5-6, once to 10. When in Race the starting reading is -1-0, but can't get the max pressure above 5. I have no idea if these readings are correct or not. I am using the D-Sport app for IOS (Apple) devices. Attached is a screen shot in Sport+ mode. |
11-07-2019, 03:01 PM | #5 |
Rep 204
11-14-2019, 10:38 PM | #6 |
Rep 113
Drives: 2018 BMW 230i Sport Line
Does anyone notice that their car jerks and throttle acts funny with the tune in sport+ or race mode or is that just me...?
